Rear Defroster problems???
Posted: April 20th, 2002, 9:12 pm
by j_villines
My rear defroster will not work the light on the button on the dash doesn't light up and the back defroster does nothing. Is there a fuse or maybe a place I can check for a wire loose or disconected. It makes it a real pain to drive when it is rainy. Any help would be appreciative!
Re: Rear Defroster problems???
Posted: April 20th, 2002, 10:55 pm
by OsoSlo z28
online shop manual
Posted: April 21st, 2002, 1:03 am
by mazda20
I have the same problem and I haven't been able to locate the problem.
Posted: April 21st, 2002, 3:06 am
by jojo2k23
Look at the rightside engine compartment.Inside the fusebox,you'll see 5 big fuses.Look at the 2nd to last one,its a 40Amp fuse.If its good then check your rear defog relay,if thats good,then check if you have voltage at the defog grid.
Posted: April 21st, 2002, 4:18 pm
by j_villines
Thanks JOJO that is very helpful one last thing were is the defog relay? Thanks for everyones help!
Posted: April 21st, 2002, 4:23 pm
by j_villines
I checked the fuses and as far as I can see they are still good I will test and see if they have power to them later and get back to you guys that are helping me get through this annoying problem. Later
