I REALLY NEED SOME HELP YOU EXPERTS!
Posted: March 30th, 2002, 12:36 am
by zx6r
Okay okay, what i've done is take the top part of the stock airbox off and thrown on a ractive heat shield cone (sounds AMAZING!).. there was a little hose attached to the side of the stock airbox which is kinda just there now..!?! what is this hose.. what do i do with it?? please help !!! =]<P>all help will be greatly appreciated!!
Re: I REALLY NEED SOME HELP YOU EXPERTS!
Posted: March 30th, 2002, 12:44 am
by OsoSlo z28
i believe it's the source for the egr solenoid valve(vacuum). some people have tapped a hole into the intake and plugged it in, and some people have just left it with out any problems...
Posted: March 30th, 2002, 12:57 am
by mazda20
If you decide to leave it alone, a good thing would be to put some type of filter on it because you still want filtered air going into your engine.
Posted: March 30th, 2002, 1:25 am
by zx6r
thanks for the quick response boys..<P>does it matter which route i GO?? filter it or try to jack it back into the intake somewhere?
Posted: March 30th, 2002, 2:42 am
by mazda20
No I don't think so, it would look nicer if you put it back in the cone, but then again mine his filtered with a sock and a tie-tie. What ever works just don't clog it.
Posted: April 2nd, 2002, 11:54 am
by Swego
I think the tubing you are refering to goes to the resonance chamber(look into the workshop manual page F1-102). I'm not sure but I believe this component is used to reduce engine noise.
Posted: April 2nd, 2002, 1:16 pm
by zx6r
Yeah, i'm not sure, i got a little air breather just for that hose, but ever since i've swapped my air filter for the cone I seem to be having some strange breathing problems.. like i'd be driving and it seems to hesitate sometimes.. not sure what the heck is wrong...<P>any ideas anyone??<P>Tawheed
