please help,wanna keep my mx-3, but not like this!!
Posted: March 9th, 2002, 10:38 pm
by mr.4 cylinder
Re: please help,wanna keep my mx-3, but not like this!!
Posted: March 9th, 2002, 11:40 pm
by dam2009
did you have done compression test ?
Posted: March 10th, 2002, 12:32 pm
by mr.4 cylinder
thanx for the reply...no,didn't have compression test done,what is a compression test?and how much ? does the problem i have sound familiar ,think it can be fixed? i like the car alot ,but i didnt by it to go as slow as regular 4 cylinder car.
![Mad :mad:](./images/smilies/icon_mad.gif)
Posted: March 11th, 2002, 12:58 am
by mazdakjs
Hey, I have run into this problem, A compression test is a great idea, your mechanic shouldve thought of it. You can buy a compression tester at your local hardware store, Is a gauge that fits into your spark plug hole, (once you have taken one out) turn it over and youll get a reading. try the plug closest to your firewall first, it usually burns hotter. if not check you distributor,. and wires.
Posted: March 11th, 2002, 1:25 am
by dam2009
you should do the compession test first ... I can almost guarantee you thats what cause your problem<BR>compression test cost around 50$ and it checks the psi in your cylinders... it should be 120psi/cylinder i had low compression when I bought my mx-3 it was caused by 2 seized valves.. it cost me aroud 500$ to get it fixed (new valves, head gasket,labor,) when my compression was low in 1st cylinder I could not go over 140km/h <BR>and sometimes on a red light it died on me ... (manual trans) so that could be it.<BR>You could get done that test by yourself.. by doing "dry compression test" all you need is the tester tool... around 30$ remove the spark plugs, screw in the tester and crank your engine 5 times, if the psi is below 110 then you know what... remember to check all 4 cylinders... good luck
Posted: March 11th, 2002, 2:29 pm
by mr.4 cylinder
hey good look on the replies ,kjs and dam2009<BR>i was gettin fustrated and was gonna sell and get another car. but im gonna try the compression test now, and see how much to fix.. cause i like the car alot.. mx-3's are one of the hottest lookin cars , plus when im drivin it feels good ,cause theres not 5000 people drivin around with mx-3's everyones got a retarded honda!
:p
Posted: March 11th, 2002, 3:56 pm
by Swego
Had a similar problem with my last car. Turned out the distributor cap would skip a contact when it was humid outside. WD-40 on the distributor fixed the problem till I changed the distributor. Check if you have good spark.
Posted: March 19th, 2002, 12:14 am
by T Biller
I think the first thing you need to do is get a new Mechanic, a bonehead that goes replacing parts without proper testing doesn't deserve $0.50 per hour. That sounds like a story from backyard Joe next door that usualy works on lawnmowers, not a certified Mechanic!
Posted: March 20th, 2002, 10:50 am
by maydusty1234
my 92 started doing that and all it was is teh feul pump going out it would bog down at about 80 and there was no acceleration now it tops out at about 140-150 and it was about 100 dollars to replace it was easy i did it myself
Posted: March 21st, 2002, 12:58 pm
by kohlf
Bro' i hade the same problem on my car as the other cat from Canada ... the compression was way off on 2 of my cylinders ... fortunately tho' my mechanic was a bit higher grade than yours ... sorry guy, its the truth, my mom is probably a better mechanic ... besides the point though ... but right now it is still not a cheap fix ... there are "0" used heads available around here that are in good shape ... I think mine is gonna cost me a mint at the end of it all ... but good luck all the same ... cheers hepcat
