Head gasket????
Posted: February 12th, 2002, 11:03 pm
by Mx_3Girl
Somebody told me that my car is liking oil from the head of the engie how can i change it???
Re: Head gasket????
Posted: February 12th, 2002, 11:05 pm
by OsoSlo z28
are you sure your head gasket is leaking or your valve cover gasket?
Re: Head gasket????
Posted: February 12th, 2002, 11:07 pm
by MrsOzx
it is probably the valve cover gasket. I had someone replace mine it was about 200. Give or take.. I would try to do it yourself and save the money.
Re: Head gasket????
Posted: February 13th, 2002, 12:05 am
by Mx_3Girl
I do not know much about car, but sometimes I could see oil around the area were the spark plugs are.
Re: Head gasket????
Posted: February 15th, 2002, 12:42 pm
by heavyfreak
is it leaking above the spark plugs, or near the bottom? if its above all you gotta do is take a socket take the bolts out form the top, theres two that are on the side where the cam cover is, but you gotta drain your oil.. and get a gasket, the gasket just pops in,.. and thers no need for a tourqe wrinch.. put them in tight.
