short shifter
short shifter
Hey I was just wondering how hard it is to install a short shifter and what the steps are to doing it yourself. I work at a garage part time so I can work on it whenever.
Steve
- David Witherow
Re: short shifter
oh man its very very simple just get under the car pull out the bolt that attaches the shifter to the linkage and then pull the shifter out put the new one in and youll need some new bushings for the linkage but pretty cheep if you get the factory ones......then you put the bolt back in...
