backup light on
Posted: August 13th, 2001, 7:18 pm
by Jesse
Does anyone know where I can disengage the reverse light? For some reason, it is always on. I can't even find out how to take out the bulbs for the reverse lights.
Re: backup light on
Posted: August 13th, 2001, 7:26 pm
by mxcess
Is the tranny auto or stick?
Re: backup light on
Posted: August 13th, 2001, 10:49 pm
by Jesse
tranny is stick
Re: backup light on
Posted: August 14th, 2001, 7:12 pm
by mxcess
The back-up switch is located on the transaxle casing. Look on the front drivers side of the tranny and you should see the switch with two wires coming out of it. I imagine you will just have to replace the switch itself. It might be in the online manual if you can't find it. Good luck.<BR>P.S. sorry couldn't be more help, but my Chilton's doesn't go into too much detail.
Re: backup light on
Posted: August 14th, 2001, 11:07 pm
by Jesse
thanks for the help, some help is better than none when I started. I'll look for the switch.
