In takes for cheap!!!
Posted: May 30th, 2001, 8:42 pm
by Guest
Hey theres a guy on on of the mazda links that made his own intake for his 4cly mazda, <BR>But I found a way to make it cheaper!,<BR>He used black pvc piping and silicon adapters from Home Depot. and then a K&N filer from a speed shop. It cam to about $75 with Filter. But At Pepboys there is a Intimidater Filter like the K&n for $25. then for the piping get a 3in exhaust pipe from AutoZOne , 3in X 4ft for $5.99 and then at Payless cash ways they have the silicone adapters for 3.99 and then a custom air valve stim for a wheel and drill a hole in the pipe and screw in the valve to plug in the airvalve that plugs in toward the front of the original air box assembly. so this comes to about $45 and their you go, And youll need to go by a custom exhaust shop that can make the bends in the exhaust pipe similar to those in the piping from the trottle body to the filter. that was $15. <BR>Craig
Re: In takes for cheap!!!
Posted: January 16th, 2003, 1:21 am
by jamario
Have you tried your custom intake? If so, did you feel any difference?
Posted: January 24th, 2003, 3:24 pm
by mixmastermark
do you have any pictures?
Posted: January 24th, 2003, 4:42 pm
by whinypunk
i made my own custom cold air, but i used dryer ducting. its too flimsy and im gonna change it in the spring. i did notice a little difference in the higher RPM's, but i would do it just for the sound. it sounds amazing. cost me about 50 bucks.
Posted: January 24th, 2003, 6:51 pm
by Timmyd865
I made mine for like 55 bux, so check it out. PVC isn't a good thing, cause it can melt and send toxic fumes into the cabin! NOT GOOD! Anyway, here's mine.
www.geocities.com/timsmx3
Posted: January 24th, 2003, 8:36 pm
by anjin1982
A muffler shop made the bends that tight i went to one and they said for 3 inch impossible maybe they aint want to mess with it...(there i go agAIN THREE DOTS)
Posted: January 24th, 2003, 10:29 pm
by hud_91gt
instead of PVC, go to your local speedshop and ask for a 3" U Bend. Magnaflow makes one, it is 14g Aluminized steel(about $35 Canadian). Then you just buy the silicon cuplings that are on intakes that you buy(They connect the Thottle body to the intake tube, and in this case the intake tube to the intake tube). Cut the U bend in half and u can make anytype of S shape tube you want.
Posted: January 25th, 2003, 12:08 am
by Marlon
Posted: January 25th, 2003, 5:38 pm
by papa roached
im gonna try that last one out soon
Posted: January 25th, 2003, 11:32 pm
by mx3man83
well i made mine for 20 bucks...cone filter from auto zone and i used electrical tape to hold it on LOL!!! Of course this is temporary, but it works. FOr now i just wanted it for the sound...
Posted: January 26th, 2003, 3:09 am
by mitmaks
just use civic intake off of ebay $25
Posted: February 10th, 2003, 1:07 am
by papa roached
im using a 99-01 corolla intake i got for free, will post some pics when i get it done
Posted: February 10th, 2003, 1:17 am
by papa roached
anyone know where i can get the rubber intake couplers at? i need one more to hoo the 3 inch pipe to my MAF
