I need the two fixed idler pulleys that ride on the back (flat) side of the GS timing belt:
Pulley #1: Between the two big cam gears, makes the belt go into a "Vee" between the gears. It's metal and is just flat b/c like I said it pushes on the back of the belt. I need the pulley, the bearing and the bolt/washer required to mount it.
Pulley #2: Below and to the right of pulley #1, this pulley is made of black plastic and has flanges on it to help guide the belt. I need the pulley, the bearing and the bolt/washer required to mount it.
(neither of these are tensioners, just fixed-position idlers)
If your bearings are still good in both or either of these, drop me a line. I need these super fast, so try and respond soon.
Email or PM works best.
-Rob
robpilgrim@hotmail.com
WTB: GS Timing belt idler pulleys
Re: WTB: GS Timing belt idler pulleys
you can get just the bearings in any autoparts store for about 6 bucks,they fit alot of cars.
AFAIK these brgs can't be replaced.Originally posted by jimishadow:
Do you have better info than me? If so, I'd love to hear/see it.
-Rob
sorry bud i was thinking idler pulley bearing.if ya need the timing belt guides i have a v6 in a wrecked car and a 4cyl in a tree fell on mx3,both run
<small>[ May 26, 2004, 08:36 AM: Message edited by: jimishadow ]</small>
No man, I was wrong! The metal idler pulley for the timing belt (the one between the two cam gears) does have replaceable brgs, friend of mine just popped them out. I do still need the little plastic timing belt idler pulley c/w bearings though, that one will not come apart for me without destroying the plastic idler pulley.Originally posted by jimishadow:
If you have this plastic idler pulley fire me an email, I want to buy it ASAP!
-Rob
I sent you an email about an hour ago. PLS get back to me, I need to get those pulleys moving fast.Originally posted by jimishadow:
-Rob
Jimi, PayPal funds sent as of 9:32pm EST.Originally posted by jimishadow:
Thanks for the help man!
-Rob
