Marco's '95GS - Budget restoration, then LPG conversion?
solo_ryder
Re: Marco's '95 GS-ZE-Black Beast - OEM sides
Post by solo_ryder »
SWEEEET
interesting, I'm about to post a similar picture in my worklog :mrgreen: :welder:
Post by wytbishop »
You guys make me sick...
Ohh...look at us...we're rich and have awesome LSD diffs...blah blah blah...
Rub my nose in it why don't you!?!?!?
fowljesse
Post by fowljesse »
Don't worry, his is painted black to cover bad machining :lol:
Seriously, though. Your car is great. In my head I'm saying that in an Irish accent (Gree-at), endind like it's a question, where the tone goes up on the last word :) I have a good fake accent.
Sorry the coilpacks didn't work. I am very jealous of your center console!
You should put your front lisence plate on a Bond style servo, so you can do crimes.
Flyer
Post by Flyer »
wytbishop wrote:You guys make me sick...
Strictly speaking, I am not rich, I just lucked out...
...probably irks you even more...
SstennizZ
Post by SstennizZ »
Awesome looking car! Where did you get that hood? And those oem sides look great with the oem front bumper.
Post by wytbishop »
Don't even get me started with you you lucky so and so...
marcdh
Post by marcdh »
HAha how did I miss this abuse for so long! $650 well spent :D
Mooneggs wrote:interesting, I'm about to post a similar picture in my worklog :mrgreen: :welder:
Have you started yet? It's not THAT bad! Drilling out ring gear is fun... :evil:
fowljesse wrote:Don't worry, his is painted black to cover bad machining :lol:
lol it does look black in that photo, yet it isn't at all! Megajizz is now back in Florida getting a good testing from Andy soon, I hope :) Yes haha with the pigs&speed cameras around here I could do with that.
SstennizZ wrote:Awesome looking car! Where did you get that hood? And those oem sides look great with the oem front bumper.
Thanks man :) Hoods off ebay, someone imported it for lots of £££, then sold mx-3 before even using it! Cheap enough too :)
View Worklog
marcdh
Post by marcdh »
Update time!
I bought the SRD rear tie bar and crossmember, second hand but never installed :) I have to say they haven't made a huge difference but it's nice to remove rusty parts for aluminium alloy that will not rust :)
Sh*t Machine plus SRD parts:
Rear Tie bar:
I also took delivery of my Mfactory helical limited slip differential :D
Porn:
To minimise downtime I got a good deal on Jon's gearbox and after some internal debate decided to DIY the job!
Once I got the OEM open differential out I had to drill out the rivets to retrieve the ring gear which I need to bolt to my LSD:
SATAN:
I also grabbed a cheap/semi rare OEM wrap around spoiler. I'm not sure about it, kinda stealthy rx7 look about it:
I'm now waiting on some parts for the gearbox before I take the LSD to a machine shop to get the carrier bearings pressed. While I'm at it I'm installing a taller 5th gear which will drop the revs 3-400 for cruising :) And new axle seals, housing, primary/secondary shaft locknuts etc.
For the installation of the gearbox I'm going to take the engine out and do some maintenance like gaskets and a good clean :)
View Worklog
Re: Marco's '95 GS-ZE-Black Beast - LSD install begins...
Post by wytbishop »
Make sure when you install the new diff that you set the backlash on the pinion gear. You will need to do some shimming on the carrier bearings. I have a G25M-R manual somewhere that says what the values are supposed to be. Any driveline shop can supply the shims.
And the wrap around spoiler is SEX!
93vtecklr
Post by 93vtecklr »
I seriously lol'd at your porn picture, mainly at the kleenex.....Does your LSD evoke any urges? :wink:
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
mitmaks
Post by mitmaks »
very well done mx3
I didn't know you had a mazdacat - that's fantastic! :D
fowljesse
Post by fowljesse »
Caed Mille Failte (Thanks) for all the pictures. I'm a little afraid to do mine. Your pics, and tutorials will give me the strength I need to press on :) Please let us know about the shims, and details.
marcdh
Post by marcdh »
Thanks for all the feedback guys :)
Took a dirty pic today, car is filthy, thought it made a change though to the usual!
I'm aquiring parts for a major overhaul atm:
clean gearbox, new end cover, axle seals + LSD
Paint suspension - most parts - (POR 15 or powdercoat?)
Wytbushings install
Strut mount bearings
Rocker gaskets
Disty o ring
Clean HLA
Check friction gear spring
Respray rocker covers
Re-polish manifold
Paint engine bay
Redo sump gasket
Paint sump
Clean block
Tap thread intermediate shaft hole
Exedy clutch
ACT six puck disc
Pilot bearing
Throw out bearing
PCV grommet
New vacuum Hoses
Header wrap, ceramic treatment if possible
Shifter bushings
New Coolant, gear oil and oil
Manual steering rack if I can locate one
In the mean time can anyone guess the tick? http://www.youtube.com/watch?v=OyoNTSPE_L8
View Worklog
