Page 6 of 6
Re: 93 MX-3 V6 hesitation issue(edited 7/15/12)
Posted: August 6th, 2012, 11:07 pm
by cWs306
Thats little random thing on the top of the disty? my cousin had the same issue but his car wouldnt start at all untill he shook the wire n moved it around a bit.
Posted: August 7th, 2012, 12:39 am
by Jazzylay20
cWs306 wrote:Thats little random thing on the top of the disty?
wtf is that the coil?
Posted: August 7th, 2012, 1:40 am
by cWs306
noo. its apart of the coil im pretty sure tho. the 3 prong plug on the back side of the 6 prong plug is the coil. multi-meter and test the 2 outter prongs on the 3 prong plug. should be 11.5-18ohms.
Re: 93 MX-3 V6 hesitation issue(edited 2/4/13)
Posted: February 5th, 2013, 12:16 am
by kyser182
So just as an update to this if anyone cares =P
So O2 Sensor solved most of the problems I was having.
Cleaned MAF and TB
Went though and checked all Vacuum hoses
Changed Spark plugs and wires
Checked Disti
Checked timing
Replaced fuel filter
The last thing i did.. and i did it sunday before the superbowl
Was check and adjust the TPS
That probably made the single largest difference out of everything. Altho im sure everything i did prior didnt hurt!
It is like driving a completely different car. I can press on the gas pedal no matter the RPM / gear
and it just GOES!
yay for all the MX-3 guys/gals!!!!
