WhiteFinish's Log there we go again
WhiteFinish
Re: WhiteFinish's Log Megasquirted p5
Post by WhiteFinish »
Still working on the megasquirt, problems with reving it higher than 4100 rpm.
Might want to take it to the crankpully sensor only instead crank and cam sensor for RPM's
Anyways
Also bought a passengerside motormount from King6
Still doubting about a good tranny mount.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
kulluminati777
Post by kulluminati777 »
why is everyone only buying the passenger side mount? I would think you wnat to change the front and rear ones for less wheel hop and the tranny one for less stress on the drive train.....is there something im missing with the passnger side mount? or was it because it IS the easiest one to change......
marcdh
Post by marcdh »
Maybe he already has AWR mounts? I know I do, and AWR didn't make a timing belt side mount when I last looked. Are you shaving off a tooth then WhiteFinish? I recommend a KLG4 pulley if you can get it, 36-1 ftw.
View Worklog
WhiteFinish
@kulluminati... AWR's are already here. Passenger side is the only one I know that fit's.
I haven't seen a plug and play tranny mount.
@marc
Yes, shaved one tooth. Will try to get a KLG4 pully. Might as well go the nice way :)
Are you using the 36-1?
Worklog click
kulluminati777
ah ha ok i thought maybe it was a new thing to only get the passenger side mount
bbunkerc397
Post by bbunkerc397 »
I also looked at King6 mounts, are you 100% sure it will fit because i was skeptical myself on the passenger side one? Also they are re-opening or something how did you buy this from them?
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
WhiteFinish
I've seen some people use it before, so it should fit.
I bought it before he closed for summer.
Worklog click
WhiteFinish
Mmm... doesn't seem that good
http://www.youtube.com/watch?v=Jwf-cDtCd8U
120-140 psi :(
Worklog click
WhiteFinish
Did a roundtrip in the Netherlands.
Picked up a KLDE for 50 bucks and a KLZE + transmission.
Current inventory :love2:
1x KLDE
2x KLZE (not working, needing rebuild)
4x transmission.
I need more space !!! :freak: :freak:
Worklog click
WhiteFinish
I've been busy taking my KLZE apart.
Now to find a good machineshop who can do some things for me.
Worklog click
WhiteFinish
Torquing the nut for the new spring on my cams
Trying to rebuild the HLA's.... with them stupid tiny balls in them !!
Progress is slow... mainly due to some unknown factors how to improve oiling and trying to find a good match between piston and rod.
Worklog click
weede_klze
Post by weede_klze »
What do you mean rebuild? Mean cleaning?
Good work btw :)
WhiteFinish
@weede... Yes, cleaning + some light polish
Ok, so the 50$ engine didn't do as well as I hoped. Also had very very low compression and a spun #6 bearing.
What the heck... I'll rebuild 2 engines than. :shrug: The KLDE testhog will be sold lateron.
-----pics are uploading now --
Worklog click
WhiteFinish
Uploading took long :mrgreen:
KLZE HLAs
KLZE crank measurements (rod/main/end)
Some KLDE goodies
Regular bearing
#6 bearing
Worklog click
WhiteFinish
Some more polishing on the HLAs
Timingbelt inner covers
Before:
After:
Testing a connecting rod from a 5.4 SBF.
much stronger / beefier and even 10% lighter.
Also brought the completely disassembled engines to the machineshop. Now my 1.2l 3 cilinder Seat suddenly was a 15 cilinder car !! :lol:
Worklog click
