This is starting to get interesting...
![Welder :welder:](./images/smilies/welder.gif)
![2 Thumbs Up :2thumbsup:](./images/smilies/2thumbsup.gif)
If you're doing an electric oil pump, that's easy. Remember that the fuel pump primes when the key is on ignition, the oil pump would naturally do the same,it would be up to you on how much time you want to let it circulate before you decide to start it.Ryan wrote:I agree that the "oil prime" idea you got going on would help an engine run longer, but I personally wouldn't put the effort into it.
Ryan wrote:![]()
9k posts and you don't know that the pump only runs when the engine is turning? (pump is triggered with NE1 signal)
The experience won't do me any harm, nor the engineRyan wrote:I agree that the "oil prime" idea you got going on would help an engine run longer, but I personally wouldn't put the effort into it.
Even shitty engines last 150-300k without it. Good ones have gone past the 1 million mile mark without a rebuild.
How long will you own your MX-3? another 5-10 years before it rots to death. Not enough to put on those 300+K that these motors run.
That's EXACTLY what I have in mind, the length of time will depend on the viscosity of the oil I'm using... I'll have a fun time finding out exactly how long it takes the moving parts to be ideally saturated in oil, that's the biggest challenge I foresee in the project. I can't imagine it would take a terribly long time though, especially with a higher pressure oil pump.Nd4SpdSe wrote:If you're doing an electric oil pump, that's easy. Remember that the fuel pump primes when the key is on ignition, the oil pump would naturally do the same,it would be up to you on how much time you want to let it circulate before you decide to start it.
