KL - DE
- brakecrasher
The Part No is KL02-13-210. The price of a new one is about 600 Euros, so you need to find one from a scrapped MX-6, Probe V6 or 626 V6. Not the Xedos 9 - that uses a MAF instead.
- brakecrasher
That's fine. You will have the same cross-wiring as with the KLZE ECU; columns E or F on the spreadsheet ,depending whether your new ECU has 3 connectors or 4.brakecrasher wrote:I think that i find a klde engine its ecu and vaf ....
And then i swap all the items!!!
Does your car have the factory-fitted immobiliser? If so, try to get the ECU from a car which also has it; then the immobiliser will continue to work. If you can, also get the harness-end which plugs into the ECU, and a second ECU to take the sockets from. Then you will be able to make an adaptor harness.
- brakecrasher
No immobiliser is good, makes it easier. Any MX-6, or V6 626/Probe. If you get the ECU with 3 connectors, it will be less cross-wiring, and won't have the immobiliser function.brakecrasher wrote:I don't have the immobilizer....
Which car's model engine i must search for the best fit?
The engines and VAFs are the same in all those cars, all years.
If the engine is '93 or earlier, use your K8 distributor.
- brakecrasher
- brakecrasher
Re: KL - DE
I've been runnning the KL-DE now for one year with only two coolant sensors. The third from the harness is just left disconnected. Is this good or bad? I haven't got any problems with it at all.Gro Harlem wrote:This means, if you get a klde with only 2 coolant sensors instead of 3, just swap the neck. If you can't fit the straight-neck manifold, use your K8 manifold.
