Put in 93 seats, they are way better than the 94+.
And finished up a front crossmember for the suspension. Sort of like a front tie bar.
EDIT: These are for the V6 model suspension only. I thought it was identical but
was wrong
hummm ok i am doing to not recomended swap of a 6cyl to a 4 cyl just picked up my donar mx-3 write off at autopac auction all windows smashed etc .. but all rest not to bad .. runs .. so if a swap everything over .. from the gs as planed will that cross member be a problem or is it a frame issue like i am thinking and can i live with out it .. ? lol
What is a BILLION.....???
A billion is a difficult number to comprehend:
A billion seconds ago it was 1959, and I was a teenager!
A billion minutes ago B.C. became A.D.
A billion hours ago our ancestors were apes.
A billion days ago no-one walked on the earth on two feet.
Yep. Theres a few things I need to get before I even consider the turbo. The Haltech will be
going in soon so I can play with it in NA mode before turboing. After that the tranny needs
new bearings, LSD, axles and a clutch capable of taking 300 or so ft/lb's of torque. After
that some injectors, fuel rail and then finally the turbo can be plopped on.
This slows things down but id rather do it correctly the first time around.
I have read conflicting information about the actual benefit of 2.5" to 3" for turbo exhauts. Lots
of time to get actual facts and make a decision, however.
