Page 5 of 6
Re: KL - DE
Posted: October 29th, 2004, 5:18 pm
by lakersfan1
Originally posted by brakecrasher:
I search for obd2 models,
Then stop it. An engine is not OBD1 or OBD2. That's just a difference in the computer. The OBD1 and OBD2 KLDE's are all the same and either will work.
Posted: January 8th, 2005, 10:57 am
by brakecrasher
Hi guys!!!
I start the search of the myth....
But I don't understand all i have to find.....
My mx3 is a 1.8 v6 of '97
I must find a 2.5 klde engine with a obd2 ecu....(right?)
Please help me
Tell me some sites where i can find them
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
Posted: January 8th, 2005, 11:23 am
by mxmaz
No. Just get ANY klde engine. I dont think the obd2 ecu will mate with your existing engine harness either. So maybe the easiest thing you could do is run the engine with you current k8 ecu, and get a kl02 vaf, which is the stock vaf for cars with a klde engine.
by Macen
Posted: January 8th, 2005, 11:47 am
by 2fazed
I just did the KLDE swap a few weeks ago. I put a 93 626 V6 in my 93 GS. All the sensors and plugs were the same. I had to swap the exhaust manifold from the K8, cause only one side, were you bolt them on matched. ECU and VAF, you need to swap. It would be a good idea to replace all the gaskets and belts, since it's alot easier to do when the engines out.
Posted: January 8th, 2005, 12:23 pm
by brakecrasher
Thanks for the answer 2fazed, but i have to do some questions....
What you wrote doesn't mate that mxmaz....
And if i use my current vaf? Maybe can it work?
Posted: January 8th, 2005, 3:30 pm
by mxmaz
do u mean run it with your stock ecu and vaf? if so, that is not a good combination. It will run really rich.
Posted: January 9th, 2005, 5:29 am
by brakecrasher
No i mean run with the stock vaf and obd2 ecu (not the stock) the klde 2.5 ecu
Posted: January 9th, 2005, 11:25 am
by IanL
brakecrasher wrote:No i mean run with the stock vaf and obd2 ecu (not the stock) the klde 2.5 ecu
Use a KLDE VAF, the stock K8 VAF is wrong for a KLDE.
Posted: January 9th, 2005, 11:26 am
by lakersfan1
Is your English really that bad? Didn't we already answer this same question ten different ways on this thread? Is this a practical joke?
Posted: January 9th, 2005, 1:33 pm
by brakecrasher
@lakersfan
maybe i'm only deaf
Posted: January 9th, 2005, 1:54 pm
by mxmaz
The klde ecu will not plug into your wiring harness (for some reason the obd2 wiring harnesses were different). Thats why the easiest, and cheapest thing to do is keep your stock ecu and get a kl02 vaf. You can usually find the vaf on probetalk.com for probably $40 or so.
Posted: January 9th, 2005, 2:08 pm
by lakersfan1
Utilizzi il vostro calcolatore attuale dell'automobile. Ottenga un nuovo tester del flusso d'aria da un KLDE
Posted: January 10th, 2005, 12:59 pm
by brakecrasher
2fazed and IanL says that i had to swap the ecu and vaf........
lafersfan1 and mxmaz says thas i can keep my ecu and swap only the vaf...
Which is the best solution?
Talk about it and tell me, because i realy don't know what to do...
Posted: January 10th, 2005, 1:08 pm
by lakersfan1
Best or
easiest that'll work pretty well??? Doing the ECU and harness change is going to be extremely time consuming, but will probably give you a few extra HP. Just changing the VAF to KL02 will take you literally 5 minutes to do, and should work pretty well.
