Then stop it. An engine is not OBD1 or OBD2. That's just a difference in the computer. The OBD1 and OBD2 KLDE's are all the same and either will work.Originally posted by brakecrasher:
I search for obd2 models,
KL - DE
Re: KL - DE
- brakecrasher
Brakecrasher: Check this thread:
http://www.mx-3.com/phpbb2/viewtopic.php?t=26248
- 2fazed
I just did the KLDE swap a few weeks ago. I put a 93 626 V6 in my 93 GS. All the sensors and plugs were the same. I had to swap the exhaust manifold from the K8, cause only one side, were you bolt them on matched. ECU and VAF, you need to swap. It would be a good idea to replace all the gaskets and belts, since it's alot easier to do when the engines out.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
- brakecrasher
- brakecrasher
Use a KLDE VAF, the stock K8 VAF is wrong for a KLDE.brakecrasher wrote:No i mean run with the stock vaf and obd2 ecu (not the stock) the klde 2.5 ecu
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
- brakecrasher
- brakecrasher
Best or easiest that'll work pretty well??? Doing the ECU and harness change is going to be extremely time consuming, but will probably give you a few extra HP. Just changing the VAF to KL02 will take you literally 5 minutes to do, and should work pretty well.brakecrasher wrote: Which is the best solution?
