[FS] NGK RC-ZE25 Plug lead / spark plug wire sets
benyandthejets
- WhiteFinish
Re: [FS] NGK RC-ZE25 Plug lead / spark plug wire sets
WhiteFinish wrote:Also interested in a set shipped to Netherlands
Postman2K
Just an FYI to everyone buying these wire sets. RC-ZE25 is used for 1992-1993, and RC-ZE35 is used for 1994-1995. Also don't quote me on this but I believe RC-ZE25 wires are 7mm, while RC-ZE35 wires are 9mm, hence the reason why they are more expensive. check out the links for yourselves.
RC-ZE25 - http://rpmware.com/catalog/item/145052
RC-ZE35 - http://rpmware.com/catalog/item/145122
2007 Mazda3 GT Hatchback (Phantom Blue Mica) - DAILY DRIVER
2004 Mazda3 GT Hatchback (Passion Lava Orange) - FOR SALE
1994 Mazda Mx-3 GS (Laguna Blue) - RETIRED/JUNKED
1995 Mazda Mx-3 RS (Dark blue) - SOLD
- projectB10
um.....no that's not quite right. I think the best source of part number to model information is the NGK catalogue.Postman2K wrote:Just an FYI to everyone buying these wire sets. RC-ZE25 is used for 1992-1993, and RC-ZE35 is used for 1994-1995. Also don't quote me on this but I believe RC-ZE25 wires are 7mm, while RC-ZE35 wires are 9mm, hence the reason why they are more expensive. check out the links for yourselves.
That shows that 2 NGK ignition wire part number listings are given for the MX-3 over its model life; RC-ZE25 and RC-ZE28. You might need to ctrl + the page to zoom the images to make them easier to read.
However the two part listings are very different in the physical length of the plug leads themselves. RC-ZE25 below
and RC-ZE28
The RC-ZE28 plug wire set, has 3 leads within the set, that are much longer than the RC-ZE25 equivalent and when installed looks really messy when used in place of the RC-ZE25. I have also seen the ZE28 set listed for the KF and KL engines which probably explains why some of the wires are "extra" length when installed on the K8. That is because the "wire run" when installed on those engines takes a different path across the engine and manifold.
The RC-ZE35 set does cross reference to a specific K8 Mazda Part #
As far as I can work out the ZE35 set is a 7mm configuration but has a different construction and resistance specification.
Maybe someone can track down the significance of the "odd" Mazda part # K834-18-140B and throw some light on how the ZE35 set fits in to all of this.
Chris
- projectB10
Bump
still available.
still available.
- mazdaspeed23
how much to ship to Canada postal code K0k2p0
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
- projectB10
bump
- projectB10
All sold thanks
The last sets went off to Luxembourg.
- projectB10
Did a stock take. Big clean up in the shed. Two sets left.
If you are interested get in touch and we can work something out.
