Nd4SpdSe wrote:I'm curious, and the measurements could be handy for Jim; you've seen my tweak to fix the CS bar...wonder if it would fit/have clearance if the bar was on the front side rather than the rear with the tweak.crazycanadian wrote:I have a CS bar to use as a comparison.. I am meeting up with Bornsticky tonight who have a curve neck ZE.. We will be taking a bunch of measurements so that Jim can tailor his bar to hopefully clear the hood and strut bar...
I got some measurements... Bornsticky all ready has a cheaper version of the CS bar installed.. The measurements were almost the same between the 2 bars... His had been installed, and allowed to rub untill it made room to fit... There is 1 bolt on the curve neck manifolds thats a big problem.. The only real way around it is like what you did... The bar needs to be move more to the fire wall to clear both the manifold and the hood...
