Page 4 of 5
Re: Ze failed missions testing (Still Failing, Help Please)
Posted: May 26th, 2011, 4:59 pm
by muttpower
Just curious, but what kind of ecu/vaf combo are you running??? If it's a chipped ecu, and the fuel map was set too rich, would that not be a possible reason????
Posted: May 26th, 2011, 9:29 pm
by Daninski
Yes what ECU are you using? I'm using AMSOIL and my emission test went way better this year. I recommend you Seafoam the engine anyway as a bottle is only 12 bucks at WalMart. I did my engine just days before the test. High flow cats are notorious for failing emissions test IAW a friend at a test center. Like I said before, ask the test guy to keep the RPM as close to 2300 not 2500 as I found the HC much lower at the lower RPM.
For your CO that's the job of the EGR isn't it but we don't use one. It's my opinion a new stock cat would help you. I used about 5oz of acetone as well and it's common knowledge you should use the 10% ethanol/methanol blended fuel not gas line antifreeze.
My Test
2500 (2300) rpm. HC 169, CO 1.34
IDLE rpm. HC 179, CO .42
I have a 2.5" exhaust and I feel that contributes to a rich running engine.
Posted: May 27th, 2011, 12:40 am
by solo_ryder
Seafoamed the car before I sold it and those plugs were done in fall of last year, they should be good and I gapped them correctly.
Check the OHM resistance in the wires.. Also, I agree with Dan. Run a new oem style cat to replicate a normal stock setup.
Posted: May 27th, 2011, 3:46 am
by mikeinaus
any chance the new o2s faulty heater could be throwing the CO emission off so far from the previous test? 1st 2 tests were with original o2s and last 2 were with the new ones.
car has a probinator chipped mx3 ecu, curved neck intake and the stock mx3 vaf as far as i know.
Posted: May 27th, 2011, 12:10 pm
by muttpower
I'm still thinking it's the probinator chip...wouldn't be the first time it caused a ze to run too rich. Here's an example...down towards the bottom:
http://www.mx6.com/forums/canada-buy-se ... eeded.html
If you had a non chipped ecu, I think it'd be worth a shot...
Posted: May 27th, 2011, 12:27 pm
by Daninski
The O2 heater is only used to initially heat the sensor, once the engine is hot it's no longer needed so if it was bad it wouldn't matter anyway.
Posted: May 27th, 2011, 12:47 pm
by Ryan
go back to stock as much as possible.
EGR, newest and best cat you can afford, 2.5 un-chipped ECM, and then it should be good, Mazda wouldn't build them to fail from factory.
Posted: May 27th, 2011, 12:55 pm
by solo_ryder
I have run a kl01 on that car and it ran good. I would try to find a kl47 ecu and run that
Posted: May 27th, 2011, 3:50 pm
by mikeinaus
Ryan wrote:go back to stock as much as possible.
dont i need to swap heads with a de to attach an egr? as far as i remember the egr bolted onto the rear cylinder head? im gonna give this shop a try with it and see what happens.
Posted: May 27th, 2011, 4:05 pm
by Mooneggs
The way I passed emissions last time was doing this:
Driving the car hard right before going to the station (hard acceleration, high speed)
After that pull over and doing the following:
2 20 oz bottles of acetone (90% isopropyl) on a mostly empty gas tank
Remove air filter
Unplug PCV valve
Last test results:
Idle emissions: HC 164, CO 0.4187
CO+CO2 14
I've actually got to go pass the test again tomorrow. I'll let you know how it goes... hopefully I pass!
Posted: May 27th, 2011, 8:21 pm
by Daninski
SeaFoam that puppy Moon (I cheated last time by pulling the PVC but this time I passed easily without removing it). Acetone is the demon sheet for sure. Actually acetone does a lot of good stuff, research it.
Posted: May 27th, 2011, 10:31 pm
by Sleeper6
for all you guys that have to pass emissions, why dont you just make a double/triple cat setup that can bolt in like a test pipe? Wouldnt that be a whole lot easier than all this chemistry and plug wire deals, install multiple cats pass test then remove and reinstall is what i would do.
Posted: May 28th, 2011, 12:24 am
by solo_ryder
^ This
Posted: May 28th, 2011, 2:46 am
by mikeinaus
Sleeper6 wrote:for all you guys that have to pass emissions, why dont you just make a double/triple cat setup that can bolt in like a test pipe? Wouldnt that be a whole lot easier than all this chemistry and plug wire deals, install multiple cats pass test then remove and reinstall is what i would do.
been there. done that. still failed
Posted: May 28th, 2011, 9:10 am
by Ryan
Make about 10L of homebrew and run her on that
