Page 4 of 10
Re: WhiteFinish's Log
Posted: February 7th, 2012, 2:02 pm
by IMACHU2
Nice looking wire set. I have never seen a set that was not an NGK that had the proper Mazda terminals.
Posted: February 8th, 2012, 2:51 am
by WhiteFinish
IMACHU2 wrote:Nice looking wire set. I have never seen a set that was not an NGK that had the proper Mazda terminals.
There are multiple ones, NGK, Magnecor, KernNelsen, Bosch
Posted: February 8th, 2012, 3:42 pm
by MrMazda92
You scored some goodies! Have you bolted your new headers on yet? Do you plan on wrapping them, as you did with the OBX?
One more nit picky question, how long do you expect a rebuilt G series trans to shift smooth as butter? I've been debating rebuilding one, and rebuilding my current one after swapping...
Posted: February 9th, 2012, 2:51 am
by WhiteFinish
MrMazda92 wrote:You scored some goodies! Have you bolted your new headers on yet? Do you plan on wrapping them, as you did with the OBX?
I plan on ceramic coating the headers.
When rebuilding a transmission it depends on what you replace. If the synchro rings are replaced it should shift very well for a long time. Off course everything depends how hard you drive / shift.
I've seen people who's tranmission start showing wear results after 100k-130k miles... others drive 200k miles with it.
Anyways... another update, worked a bit on my dash yesterday evening.
Had to adjust the bezel because otherwise the rings wouldn't fit.
Also painted the dials and put the moman indiglows in there... Of course I broke the fuel meter
Re: WhiteFinish's Log Moman gauges p4
Posted: February 9th, 2012, 4:09 am
by MrMazda92
Do those light up in red?! I want :O
Posted: February 9th, 2012, 4:14 am
by Evo_Spec
Those are the exact gauges i was looking to get, man they look really nice and also look like good quality.
MrMazda92 wrote:Do those light up in red?! I want :O
here's a link to the site, they have some lit up pictures there.
i don't think they have MPH so.....
http://moman.pl/en/index.php?a=opis&k=20&id=76
Posted: February 9th, 2012, 6:25 am
by MrMazda92
Ah, oh well... I'll make my stockers Red.
Posted: February 9th, 2012, 6:09 pm
by Josh
I used fingernail polish on mine too
Looks very good!
Posted: February 18th, 2012, 6:02 am
by WhiteFinish
The instrument gauge is put together.
Everything is hidden in the casing itself. Then hooked up to a wire in the dash and I can take everything out at once
(also because I dont have a heater bezel)
Orderd a caliper rebuild kit for my mx5 rears and mazda6 fronts.
LSD back on its way from HongKong.
So busy enough
Posted: February 18th, 2012, 5:55 pm
by mikeinaus
those gages are pimp. if only they didnt cost so much
. i love the fact they are km/h too
Posted: March 7th, 2012, 10:27 pm
by DeadMaker
Hi..
I have a question about brakes.
http://seekpart24.com/jakoparts/brake-c ... 2?c=100807
From the list of fitment it seems that mx6 323 626 and xedos6 calipers are interchanchable
So a steering knuckle from xedos6 must be the same with 323 v6
This is a steering knuckle from xedos 6
Is this the same with 323f v6 knuckle you used?
Thanks
Posted: March 7th, 2012, 10:48 pm
by mikeinaus
look at the vehicles supported tab. you need the 323f V6 knuckles for this. the 323 that uses the mx6 brakes is the 4 banger...
Posted: March 8th, 2012, 5:19 am
by DeadMaker
But this knuckle in the pic i show is with 5 banger.
That's why i ask..
Posted: March 8th, 2012, 5:24 am
by WhiteFinish
I'm sorry. I can't answer any questions towards this because I used a concept from Wyshbishop and weede klze.
I didn't do any measurements.
Posted: March 8th, 2012, 11:32 am
by marcdh
Thanks
Nope:
Sorry for more worklog clutter
Those gauges are lovely!
