_-Night-Shade-_ [ 1994 GS-R ] - Winter 2012 ... Part 1
- _-Night-Shade-_
Re: _-Night-Shade-_'s Worklog
Make sure to post pics (but as a link), I wanna see how it looks.
I got a pic of it in the day, but not one at night. I posted it in the appearance forum!
- tripleMX-3chicMS
Sweeeeeeeeeeeeeeeeeeet
93*4 GS SE's for parts ONLY*
- _-Night-Shade-_
Hey guys finally got an update for you. Sorry it took so long, it was hard to find time between full-time school, work, and just other things in life. Still on my list is the curved neck IM and the probinator chip before I can start the swap. But I'm gonna leave that till it's closer to spring anyways. So yeah, I got started today!
Here is the workspace:
You can see the ZE in the corner chilling.
Got the car lifted up, ready to work on:
I finally found out what that exhaust leak I had for the past half a year was! Lmfaooooo
Hahah, I'll have some more updates later this week for you guys! Cheers.
- Evo_Spec
Re: _-Night-Shade-_'s 1994 GS - Finally started on winter stuff!
why does your ZE have a ford cover?
- solo_ryder
Nice pics man! Can't wait to see this build!!
I think it has a ford VC cause it was in a anal probe right? Guy put that on?
- _-Night-Shade-_
Correct! I bought it used from a Probe guy. Hopefully everything's alright...
sweet collection of action figures u got on the shelf there, lol. Is it really safe to have the car jacked up like that? If so i'm doin that. Good luck with your swap bro
- _-Night-Shade-_
Hahaha bro I'm renting the garage for the winter, don't have my own I've got 2 jack stands under the rear subframe and 2 under the front one. All safe points. Also used the trailing arm housings to jack up the rear end. Safe.93SOHC wrote:sweet collection of action figures u got on the shelf there, lol. Is it really safe to have the car jacked up like that? If so i'm doin that. Good luck with your swap bro
- solo_ryder
I stored my car the whole winter one year this way. Worked well.. to bad there was permanent marks in the asphalt after from the stands... oops
- fowljesse
Re: _-Night-Shade-_'s 1994 GS - Winter build finally started!
I would have liked to have heard what that exhaust leak sounded like
- _-Night-Shade-_
So I just finished stripping the KLZE a bit: the IM is off and the valve covers are off and also prepped the car a bit more. I was gonna take some pics when I realized I forgot to bring the mounting piece for my tripod... pictures tomorrow I promise!
@ Jesse: the exhaust tone was awesome - deep and V8 sounding at low RPMs, but like an F1 at the higher ones. Except it rattled because it's pretty much broken off at that point so it's like 2 seperate pieces and they'd rattle against each other, pissed me off driving around like that But I'm pretty sure it will still sound badass once it's fixed - it's the Magnaflows afterall =P
- _-Night-Shade-_
Pics:
MX-3 stripped down a little bit:
KL-ZE stripped down a little bit:
Yes I know it's a little brown but hopefully that will wash away with a couple of oil changes of synthetic. I don't really care about that as long as everything works, and so far it's looking good. The things I couldn't check for when I bought this thing are the valves and pistons/rods. The valves are looking good but I won't be able to check the pistons - I'll have to find out the hard way if something's wrong with them
- solo_ryder
Seems to be okay, the cams look good, little to no wear. Consider a kerosene flush or seafoam maybe to get that gunk outa there
- JWMX3
perfect time for colt cams !
