390 km on half a tank... Upset about fuel mileage!
93vtecklr
Re: 390 km on half a tank... Upset about fuel mileage!
Post by 93vtecklr »
Things that make you go Hmmmmmmmmmmmmmmmmm.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
Ryan
Post by Ryan »
What makes me go HMMMMM is that I'm getting the same fuel economy as the ZE's. :shock:
Ryan wrote:What makes me go HMMMMM is that I'm getting the same fuel economy as the ZE's. :shock:
wow that sucks cause I'm sure we are having more fun driving fast :driver: 8)
Whisper
Post by Whisper »
I bet you're running rich.
Now there could be various reasons for that. Your ECU, for example.
What year is your bro's Probe? Is he running the same ECU/VAF combo?
solo_ryder
Post by solo_ryder »
94 with a probinator
Whisper
Post by Whisper »
Well, let's see. Same motor. Allegedly same ECU/VAF. Same amount of coolant sensors, yeh, and they're all functioning? What about EGR? No codes?
Injectors clean and spraying efficiently?
If setups are the same and you're getting worse mileage, then you're likely running richer, so you're getting less power and wasting more fuel.
93vtecklr
Post by 93vtecklr »
I jusr hit 590 km on one tank, fuel light will come on any minute now.......
solo_ryder
Whisper wrote:Well, let's see. Same motor. Allegedly same ECU/VAF. Same amount of coolant sensors, yeh, and they're all functioning? What about EGR? No codes?
Yea, pretty much the same.. The only thing I can think is that he has his passenger side VRIS closed as it is not functioning right. I can outpull him though in a race.
Vtek.. Thats nuts, I got 400km or so last night all highway just as the light came on..
Whats your setup?
93vtecklr
Post by 93vtecklr »
I got a letter from the man about my driving techniques, I'm on my 9th demerit thanks to trying to make a yellow.... So lately I've been shifting religiously at 1750! Needless to say I'm a traffic nuisance, but my mileage has gone through the roof!!! You got a klze too, mine is the k8ze. I'm now at 611 and still no light!!!
solo_ryder
I have no tach hahaha.
Crazy mileage there... I am running shell 91 and that really seems to help me get a few extra mpg. Guess I was running to rich of a octane before
93vtecklr
Post by 93vtecklr »
Could be, i run 87 octane.
Collier
Post by Collier »
With all other variables the same, I replaced the air filter and got my tire's pressure up to spec and gained close to 5 mpg.
Granted, it was gaining BACK those 5 mpg.
Hoodzy
Post by Hoodzy »
It seems like you are comparing apples to oranges. Sure you have the same engine but you mentioned all the added parts. Things may not be working 100%, depends on maintenance and life of the engine, driving style, weight of vehicle, gear ratios, wheel weights, air in your tires, drag there are so many factors other then having the same engine.
1995 Creek Mica Blue GS
solo_ryder
Hoodzy wrote:It seems like you are comparing apples to oranges. Sure you have the same engine but you mentioned all the added parts. Things may not be working 100%, depends on maintenance and life of the engine, driving style, weight of vehicle, gear ratios, wheel weights, air in your tires, drag there are so many factors other then having the same engine.
I disagree.
His motor has higher miles and not as clean as mine internally, its heavier, wider tires, same weight rims, same tranny, same psi of air in tires (41 psi) and more drag then a mx3 iirc. We can follow each other on the same road for 300km and both fill up, I would have to put in much more.
He lost his license for the 3rd time. So I am gonna snag his ecu and VAF and see what happens. I will report back
Flyer
Post by Flyer »
Well, I have no gas light...
Average fuel economy as of this moment is about 10.1L/100km (23.29mpg for you Imperial dogs) with a stock K8 (and I mean completely stock, even stock airbox) with a leaky gas tank...
