Page 4 of 4
Posted: April 14th, 2006, 12:53 am
by cjthor
Ordered my turbo today! Went with the GT2871R with Vband clamped 3 inch downpipe. No gaskets to blow out! Also concidering a boost sensitive cut out for the downpipe. Sure would be nice to be able to have a straight pipe on command under booooost.
Posted: April 14th, 2006, 9:00 am
by babyblueMX3
good choice
Posted: April 14th, 2006, 4:40 pm
by osargeant
Nice turbo selection, keep us posted with the results Jarid. I am considering the GT25 series myself.
Posted: April 14th, 2006, 8:52 pm
by Cy
a good map on that turbo.. what numbers are you targeting..
Also... i noticed on your cardomain page... where did you get that half-shaft? and are you other 2 axels the same diameter??
Posted: April 14th, 2006, 9:32 pm
by cjthor
Cy wrote:a good map on that turbo.. what numbers are you targeting..
Looking for 300whp. The driveshafts are from
http://www.driveshaftshop.com . I no longer have a half shaft. I am running two shafts with a limited slip inbetween!! Amazing enough there is little or no torque steer!
Posted: April 14th, 2006, 11:24 pm
by Cy
cjthor wrote:Cy wrote:a good map on that turbo.. what numbers are you targeting..
LSD setup from them too?
Posted: April 15th, 2006, 2:13 am
by cjthor
Cy wrote:cjthor wrote:Cy wrote:a good map on that turbo.. what numbers are you targeting..
na Mazdaspeed LSD in my protege tranny.
Posted: April 26th, 2006, 11:13 pm
by MazdaManiacMx3
Nice choice , If I had visited the site more I would have posted this earlier I would have went with the GT28 or a turbo that you guys looked right past (and I dont know why they don't use this more often on low boost v6's .) The T3/t4 To4b A little smaller than the to4e but still puts out good numbers for a good price , A low budget substitute to the GT series, but of course the savings does sacrafice performance , Ball bearing turbos are Niiicccee
