Turbo experts..I need your help.
- cjthor
Ordered my turbo today! Went with the GT2871R with Vband clamped 3 inch downpipe. No gaskets to blow out! Also concidering a boost sensitive cut out for the downpipe. Sure would be nice to be able to have a straight pipe on command under booooost.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- babyblueMX3
Nice turbo selection, keep us posted with the results Jarid. I am considering the GT25 series myself.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- cjthor
Looking for 300whp. The driveshafts are from http://www.driveshaftshop.com . I no longer have a half shaft. I am running two shafts with a limited slip inbetween!! Amazing enough there is little or no torque steer!Cy wrote:a good map on that turbo.. what numbers are you targeting..
Also... i noticed on your cardomain page... where did you get that half-shaft? and are you other 2 axels the same diameter??
Jarid Perry
LSD setup from them too?cjthor wrote:Looking for 300whp. The driveshafts are from http://www.driveshaftshop.com . I no longer have a half shaft. I am running two shafts with a limited slip inbetween!! Amazing enough there is little or no torque steer!Cy wrote:a good map on that turbo.. what numbers are you targeting..
- cjthor
na Mazdaspeed LSD in my protege tranny.Cy wrote:LSD setup from them too?cjthor wrote:Looking for 300whp. The driveshafts are from http://www.driveshaftshop.com . I no longer have a half shaft. I am running two shafts with a limited slip inbetween!! Amazing enough there is little or no torque steer!Cy wrote:a good map on that turbo.. what numbers are you targeting..
Jarid Perry
Nice choice , If I had visited the site more I would have posted this earlier I would have went with the GT28 or a turbo that you guys looked right past (and I dont know why they don't use this more often on low boost v6's .) The T3/t4 To4b A little smaller than the to4e but still puts out good numbers for a good price , A low budget substitute to the GT series, but of course the savings does sacrafice performance , Ball bearing turbos are Niiicccee ![Smile :)](./images/smilies/icon_smile.gif)
93 Kandy Tangerine Mx3 GS-DE
05 Saab 9-2x (Wrx power plant)
02 Subaru Impreza OBS
05 Subaru forester Xt - sti mods
04 dodge ram - toy hauler -FOR SALE
& Lots of Toys to haul![Very Happy :D](./images/smilies/icon_biggrin.gif)
