Spent the morning fixing the broken expansion union on the rad so I drilled it out and inserted something a bit more hefty and epoxied in place, fingers crossed it holds!
Also while rad was out swapped out all the green hoses to black.
This is correct none of the European bumpers have em i was going to swap mine out with a friend of mines car but i like the short license plate space better then the long oneMooneggs wrote:that bumper doesn't have side markers, correct?
Josh wrote:Well with stock boost level and proper injectors with a Boost sensitive fuel pressure regulator it should be fine and reliable. I ended up swapping the 1.6 ecu and engine bay wire harness for a older 92-93 harness and a BP10 ecu and RX7 VAF, worked well, I also strapped the VICS wide open for better response. for stock boost levels the OE system can work just fine. my first kit i put together cost me under 1K USD.
