klze wont start
Re: klze wont start
No, once again I suggest you SeaFoam the engine as well.
Re: klze wont start
Got another disty and she runs. Going to order a new one right away.
- mazdaspeed23
Re: klze wont start
Most people when they have no spark they start changing and buying all new things before they actually try to figure it out. i dont know if anyone knows this but i will say it for shits and giggles. there's a condenser inside the disty it's self you can get spark from the coil and rotor and even have good readings with a meter. but if that condenser is gone/bad you will never get the car to start without replacing the disty.. usually when theres no spark, the first thing i do is eliminate stuff thats easy, smell for gas.. then i check the spark plugs for spark, if no spark, then you go to the disty, in order to get any spark to the plugs, it has to go through the disty. use a meter to check the disty etc.
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
