Winter warmup time?
mikeinaus
Re: Winter warmup time?
Post by mikeinaus »
yeah i reread what i originally wrote. your right, i dont know what was going on in my head at that point. i know better then that.
DeadMaker
Post by DeadMaker »
So Mazda says 10w30 and not 10w40..Didn't know that..Always used 10w40.
So first rule read the F*manual.
Black Mazda Mx3 Rs 1997 B6DE
SBR
Post by SBR »
MrMazda92 wrote:
SBR wrote:Am I lucky or something?
Something:
SBR wrote:New thermostat and coolant (65/35 coolant/water), Castrol Syntec 5W50, GM Synchromesh Friction Modified.
Mind you this was BEFORE changing them. Before changing coolant + thermostat, colder temps when I tried using the heat. Didn't affect how fast it warmed up.
And still irrelevant to cold shifting because the set are not related. If it was, I'd suggest changing fluids, but that wasn't the case. Shifted same before and after, but I changed it because I didn't know how good the current fluid was.
Black 1993 Mazda MX-3 GS - daily driver
Kenwood BT-948HD, MB Quart FX4.100 and ONX1.1000D, Polk MM6501 x4, Polk MM1240
SE interior, MOMO Endurance shift boot, Tomei long shift knob, eBay short shifter
Red 1987 Toyota MR2 - go kart
"If it's crazy you want, it's crazy you get."
MrMazda92
Post by MrMazda92 »
The fluid made a minor difference for me, I bought another brand to try come swap day. :2thumbsup:
Return to “Transmissions”
