SuperK's '93 ZE - "Bane"
- MrMazda92
Re: SuperK's '93 ZE - "Bane"
Did that come apart that clean, or did you clean it up after?
That's a clean engine, what're the original miles? I soaked some cylinder heads(VT was removed) in de-greaser for 2 days and yanked them out, they came out looking brand new. I wish the rest of the engine was so easy to clean!
Valvecovers alone take a good amount of time in the blast cabinet.
Good work, I can't wait to see where you take this!
The engine seems quite low milage, there wasn't much sludge buildup in the engine... but I've been cleaning a lot of it as well... It is a quite clean engine! This is what it looked like before I touched it with any solvent
Then again, I've had my hands in the engine bay every week for years now, and only driven it a handful of miles, so that helps too
- MrMazda92
Well it's definitely pretty clean, I'd estimate 60,000-90,000 miles for the heads, so you're doing something right!
Those ValveCovers honestly don't look like metal, what kind of paint was used on them? They remind me of the newer Plastic shielded IMs honestly
Slow going. I got my valve spring compressor today, but I stayed up too late last night, woke up too late today, didn't have much time to work on the engine. I was able to remove the springs though.
I am having a blast with this. Usually I have the heads taken to a shop to replace the stem seals and all... Learning this myself is just incredible.
Oops, speaking of which, I forgot to order some stem seals... BRB!
- MrMazda92
Nice!!
What type of compressor did you end up buying? I snagged a Craftsman model from Sears, cut a deep well socket(notched it) to remove the keepers, and went to town on my heads. The reason for the modification was that they only had an OHV ValveSpring compressor in stock at the time.
It's coming along though, nice!!
I believe it was OTC? Brand from amazon, I got the oversized one.
- WhiteFinish
Looks good...
Do you made some more pictures of the process? I'm going into it soon as well.... so would love to learn more.
Anything in particular you'd like to know about? I can take pictures and send them to you if you want to know about anything specific.
Removed:
valves/springs/retainers from both heads
Just In:
Clutchmasters Flywheel
Clutchmasters Stage 1 Clutch
OEM New Harmonic Balancer
Fancy Schmancy looking Clevite Bearings
That's a no bueno connecting rod...
- WhiteFinish
Mmm... I hear benned is the new straight
it'll buff out.
- diezzel
Wyt 's alive .
Thot thar is what we likes to call, "an optical confusion", thas one straight azz connecting rod regardless.
Pretty sick man! Im rebuilding a motor too! Could u shoot me a link on the valve spring compressor i need one.. Anyways question u might be able to answer for me.. When i took my heads off and looked at the pistons/cyl there was still hone marks in the bores should i rering and new bearings?
