I ended up running the stock fuel injectors and a BEGi fmu and a wally 255hp in-tank fuel pump. I did not modify the fuel pump to do away with the +85psi bypass. 85psi with the 190cc injectors are plenty with that pump. I have more than enough fuel for 7-9 psi with the td04h 13g in the 5cm^2 turbine housing. It spools the turbo plenty fast enough, hitting 5psi before 4k without a ball and spring boost controller (using a fuso 20g wastegate actuator because it agrees with the angle i have to clock the housings for everything to work). If a ball and spring controller is used, it spikes to 8 psi then settles to 5 at 3300rpms
![Freak :freak:](./images/smilies/freak.gif)
. . .Far too quick for my comfort level. The universal BTM is VERY VERY well suited for this setup. I simply pull timing when boost tells it things are going to get crazy, and I dont feel a loss in power or a transition or anything. VERY good investment.
In all, the mx3 1.6L motor LOVES boost. It runs smooth through to redline. The more throttle you give it, the more it likes. The rods apparently handle the "boost" just fine. Which means that with this turbo, 8psi at the timing curve I am producing and the fuel I am flowing is just fine for months of abuse. Totally different animal than when I had the big muffler, no turbo, highflow intake, and k&n filter, with the timing set to 15deg advance vs. stock 10deg. I am even running the stock intake box and actually threw in the stock paper air filter, as you can see in the pics. I never put timing back to stock. I just had the btm take more timing out when on boost. So throttle response is the same.
So far, I am very pleased with the little 1.6L SOHC motor with boost and would deffinately do it again if I had to. I never had more than 2 days of down time. It is daily driven from Sanford VA to Birdsnest VA.
