Page 3 of 4
Re: tehbrookzorz - Project KL-T
Posted: April 11th, 2011, 9:37 pm
by tehbrookzorz
I'm waiting for flywheel bolts and a starter to arrive.
Here's what I'm up to:
Posted: April 18th, 2011, 2:39 am
by tehbrookzorz
I received new flywheel bolts this week, so I test fit the transmission centering the input shaft in a bushing within the new pilot bearing in the flywheel... *breathes* Later on I drilled the holes for the transmission.
Posted: May 15th, 2011, 1:12 am
by tehbrookzorz
While soldering my harness, I found mistakes in the diagram. The chart should be correct though.
Most recent test fits:
Posted: May 15th, 2011, 1:51 am
by Evo_Spec
lookin good! can't wait to see it mounted and running!
Posted: June 6th, 2011, 10:38 pm
by tehbrookzorz
Photo update:
Engine in car, with transmission bolted up. Still need motor mounts.
Shiny stuff!
Busted fuel sender, made better.
Gauge mount made from bar aluminum. Think I might change the order.
Start of the custom intake. Yeah.
Posted: June 18th, 2011, 12:10 am
by tehbrookzorz
So, a bit more progress.
My attempt at exhaust manifold flanges.
My first real welding project. Motor mounts.
My second welding project. Intake.
Posted: July 4th, 2011, 8:26 pm
by wagZE
That's an awesome sleeper man. I would never attempted that difficult of a swap, takes serious patience. I just told my gf remember that guy we met in eastern washington, I think he has a little to much time on his hands lol. Awesome job so far.
Posted: July 4th, 2011, 11:34 pm
by tehbrookzorz
I wish I had too much time. I've been fighting for every minute of this build. I'm too popular at work. Never do your work at the shop you work for if you have a deadline.
Just for you:
Posted: July 5th, 2011, 10:47 pm
by Nd4SpdSe
Wouldn't a straight-neck IM fit?
Posted: July 6th, 2011, 12:21 am
by tehbrookzorz
Not unless I cut a hole in my firewall.
Posted: July 6th, 2011, 12:19 pm
by Sleeper6
So out of curiousity how do you plan on securing your manifold down? Those center bolts look like they will be a real pita to get too. Not only that but are those rear runners going to recieve sufficent air flow? Otherwise I like the look of it, looks real aggresive similar to the new GTR aftmkt manifolds you see.
Posted: July 10th, 2011, 5:53 pm
by Nd4SpdSe
tehbrookzorz wrote:Not unless I cut a hole in my firewall.
Oh shoot, I didn't notice it was facing the other way!
Even if you rotated the IM 180 degrees, but I'm sure you already tried that...
Posted: July 11th, 2011, 12:28 am
by wagZE
Sleeper6 wrote:So out of curiousity how do you plan on securing your manifold down? Those center bolts look like they will be a real pita to get too. Not only that but are those rear runners going to recieve sufficent air flow? Otherwise I like the look of it, looks real aggresive similar to the new GTR aftmkt manifolds you see.
Yea a PITA looks like an understatement. I'd expect to see some metal tubes at every bolthole location to get them in with a long extension. That IM looks f'n sweet though, I foresee a hood scoop also?
Posted: September 11th, 2011, 1:26 am
by Ze-86
Wow I'm glad I was directed to ur post...I'm planning on a similar swap (k8ze/13b 93+ tranny in ae86) it's great to see a bit of what I have to go thru, except I need a custom drive shaft (240sx suspension/ r34 diff) .... U shud paint the Celi blk and slam it ... At nite ...with that kl exhaust note...ppl will be lost
(was that a farrari ???) Cool beans man, lookin fwd to seeing the finished product!
Posted: September 26th, 2011, 11:11 pm
by tehbrookzorz
I was contemplating the Death Race Mustang paint scheme...
Another thing to look at would be the clearance of your steering column shaft. Aftermarket headers won't fit in my bay, and an AE86 is smaller IIRC.
Link me to your build if you get serious with it.
