Page 3 of 15
Re: RS_OBD'oh_2's 1996 RS + T
Posted: June 30th, 2009, 7:29 pm
by RS_OBD'oh_2
Posted: July 4th, 2009, 3:44 am
by RS_OBD'oh_2
Posted: July 7th, 2009, 4:20 pm
by RS_OBD'oh_2
added new valve cover. Now the rest of the bay needs a good scrub down.
![Image](http://i289.photobucket.com/albums/ll240/mx3_photo/IMG_2875.jpg)
Posted: July 8th, 2009, 3:50 am
by RS_OBD'oh_2
Posted: July 21st, 2009, 1:20 am
by RS_OBD'oh_2
oil feed and return are done. Pics up soon.
Posted: July 21st, 2009, 7:30 pm
by RS_OBD'oh_2
gettin oily
So the feed fittings are as follows:
1. 1/8bspt (male) to 1/8npt (female)
2. 1/8npt (male) to 1/8npt (female) - oil pressure reduction to save turbo seals
3. 1/8 (male) to -4AN (male) elbow
4. -4 oil line
For the oil pan I drilled a hole and placed in a -10 an bulkhead. It has teflon washers on either side of the hold. I added a little extra sealant prevent leaks. The bulkhead is made for fuel cells.. so oil should not be an issue.
![Image](http://i289.photobucket.com/albums/ll240/mx3_photo/IMG_2993.jpg)
Posted: July 24th, 2009, 12:00 am
by RS_OBD'oh_2
Posted: July 24th, 2009, 12:35 am
by Evo_Spec
getting closer!
totally wanna check it out when ur done!
Posted: July 24th, 2009, 9:31 am
by RS_OBD'oh_2
I'm getting pretty pumped myself. I could start it tonight. Just need new oil and a filter... I'm sure it will be mega rich and maybe even shoot a little fire out the dump. I'll probably wait a day and upgrade the sw on my f/ic 1st.
Posted: July 24th, 2009, 12:49 pm
by DanSankey
thats some top work there mate, did you make the boost pipes yourself or buy them? they look spoot on
, cant wait to get cracking on with mine now
![Welder :welder:](./images/smilies/welder.gif)
Posted: July 24th, 2009, 5:45 pm
by RS_OBD'oh_2
it's a kit that you have to cut and weld yourself. The part number and link can be found on page one (1) of the Worklog.
Posted: August 5th, 2009, 6:46 pm
by RS_OBD'oh_2
Posted: September 4th, 2009, 5:36 pm
by RS_OBD'oh_2
Air intake done. I used a probe GT short ram ($15.00 ebay). The pipe had the correct size nipples for the factory hoses. The center nipple is capped for now, while I am using a breather filter for the valve cover port.
The filter is AEM dryflow.
![Image](http://i289.photobucket.com/albums/ll240/mx3_photo/IMG_3055.jpg)
Posted: September 4th, 2009, 6:43 pm
by 93vtecklr
![Shocked :shock:](./images/smilies/icon_eek.gif)
I'm in love, bromance dude, bromance!
Posted: September 4th, 2009, 8:03 pm
by edger0587
question for you. After installing the cold air intake, what did you do to the little tubes that connected to the air box. Mine are just dangling, and I'm wondering if that would cause any problems. THere is some sort of sensor attached to it.
