That tree assumes that a code is set.
Check the post above.
Customer is unhappy (car has a miss), no codes.
Obviously a labscope confirmed and fixed it.
Also, if i was in that situation that the tree is appropiate for. I would (without having to read that tree) pintest the sensor terminals with a lab scope. Looking at all the voltages. You guys out there should know you can have noise or glitches on the power and ground feeds causing driveability issues that won't show on a multimeter. So you could miss the problem. You could read an acceptable ground on your multimeter but a spike can cause a miss Check out the bad grounds below. If you used a multimeter versus a labscope while performing mazdas tree you would miss the bad ground. Checkout the waveform with the spike. The time scale is set set to 20 Microseconds per division. IF a multimeter could catch that you would never see it.
I am an ASE master tech, advanced engine performance certified.
Former fuel and electrical specialist in the marine corps. With those titles came much schooling.
Every automotive driveability school ive been to stresses the use of labscopes.
Tool manufacturers invest a lot in producing labscopes, And your average technician i.e. joelunchbox spends thousands in purchasing labscopes.
Diagnostic aids and libraries have stored waveform libraries for the unsure technician.
Why would techs pay thousands versus hundreds for a multimeter if it wasn't needed.
In short there isn't one element of this industry that doesn't recognize the importance of reading waveforms.
Ive worked flatrate most of my career, The quicker you diagnose it the more money you make. If your wrong you work for free. That makes a technician keen. Get it done fast and right.
Every shop iv'e worked for (including the dealer) iv'e been the electronic diagnostic guy.
Look at the info ive put up, where do you think thas comes from. Fixing cars. I don't spend days fixing driveability problems, 99% of the time I spend minutes.
If you want to discount a labscopes importance fine. If you made your living fixing cars you wouldn't.
Bad grounds not caught by a multimeter
![Image](http://memimage.cardomain.net/member_images/11/web/2375000-2375999/2375603_28_full.jpg)
92 MX-3 GS, KL-ZE, OBX headers, 2-1/2" exhaust, XL Performance muffler, AASCO Aluminum flywheel,Pheno spacers,APEXi Airflow computer,Eibach springs,Tockico struts, Toyo RA1 205/50ZR15s, B&M short shifter. MS control arm Bushings, SS clutch line, SS brake hoses
