Dyno schedule
As you can see, on the graph, I go from ulber-rich to ultra lean at 6000rpms....
You coming friday?
seriously considering it but not sure if we all will get good runs in (amount wise) or if we will have to give way to the "pros"
Friends are just enemies who lack the testicular fortitude to kill you.
I'm a 2min man in a 1min universe
94 GS - KLZE, Spec2 Clutch, Fidanza 9lbs FW, 2 1/4 full magnaflow exhaust. 145WHP / 147WTQ
Considering they're calling for 80% rain Friday morning and 60% rain in the afternoon, we might take a rain check...and i potential have other plans
Prolly about racing 2nite, but their still calling for rain all day and throughout the evening.
As for getting both Tq and Hp on the graph, import both files, than right-click on the graph, select "Properties". Goto Axis Selection and there will be 3 example graphs. Use the top example graph. The button to the left should say "Power", the button to the right should say "None", click on it and select "Torque". Then check off "Apply Settings To Current Graph", hit "Apply" than "OK" And Voila!
Wanna add the Air/Fuel graph in underneath? no problem!
On the top left of the window, under the menu's, there's 5 pictures of graphs. Click on the picture with the graph pics with 2 squiggly lines, than will show a second graph just below your first one. Right-click on the bottom empty graph, select "Properties". Goto Axis Selection and this time, on the middle graph, on the button that says "None" to the left of it, click on it and select "Air/Fuel Ratio". Then check off "Apply Settings To Current Graph", hit "Apply" than "OK". You can drag and resize both graphs buy putting the mouse cursor between the 2 graphs, and you'll get the standard drag cursor, just click and move down. Once's it's adjusted to how to like it, right-click on it and hit "Rescale".
