new sway bar for the mx-3!!!
- happyclown
I was worried that i would have to do some reinforcing... im still looking into it but i think i need to replace my rearjoints (you can shake the wheel with your hands and it clunks)...
How will this be able to replace them? Would it be very easy?
On the lightest setting will anything need reinforcing?
Deffinatly something im intrested in, but I dont wanna have to fix other things because of it...
1993 RS Teal
man you cannot get any easyer then this. first is the joints are REALLY ANNOYING TO TAKE OFF!!!! took me a dremal and a boat load of cutting disks. But the links just bolts on to where the stock ones go its really easy.
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
![Image](http://i7.photobucket.com/albums/y296/Legato626/supra%20pics/P1010277x-1.jpg)
- papa roached
got my bar today, will post up pics when i find the camera batts
- papa roached
guys, i am gonna e-mail rob at zx tuner because the bar WILL NOT FIT, it wont clear our back suspension
- papa roached
the brackets to make it bolt to the body wont clear the back suspension, they hang out to far, Legato626 could you take pics of your install?
- neutral
Legato626 wrote:man you cannot get any easyer then this. first is the joints are REALLY ANNOYING TO TAKE OFF!!!! took me a dremal and a boat load of cutting disks. But the links just bolts on to where the stock ones go its really easy.
neutral wrote:Just ordered this upgrade so here's hoping my fitment experience is more like Legato626's than papa roached. Anyone else have an easy or hard time swapping in the new ZX2 bar please post.
Did I miss something? Apparently...? How can the install "not get any easier than this," when ya haven't even received your new sway bar yet?Legato626 wrote:i haven't got mine yet!
![Image](http://i116.photobucket.com/albums/o32/jimfyp/picnic4.jpg)
- jschrauwen
