You both mentioned drilling into the top of the cap along the raised ridge, where there is a metal strip to make contact with. Do I need to cut out the whole ridge area surrounding this hole so that the plastic part of the power town seats against the rest of the cap?
And Tunes you mentioned drilling through the cap where the original coil tower tube is, and you only need to slightly enlarge the hole for the screw to connect to the power tower through here. Is this correct?
![Image](http://thumb10.webshots.net/t/60/760/2/40/21/2194240210060306730kAHAYv_th.jpg)
Yellow is through the original coil tower hole/tube
Red would put it somewhere in the area between the center and the side of the tube.
Anyone got pics?
