"touch"
I HIGHLY doubt that it could cause a gas fire.. Considering sometimes sparkplugs have a tough time igniting the fuel. And that is under compressed conditions. You'd need quite a bit more energy for that. Cigarettes on the otherhand are hot, and heat will ignite it easy.Macen wrote:I use it almost every time I step out of the car. I love the thingy
You all should touch it before you fill the tank with gas. The zap can ignite the gas. So why risk your precious by not touching this awesome button?
I COULD be wrong, but I am pretty sure of this.
Macen wrote:The guys at Mythbusters have tried the "spark at gas station" myth, and it was not busted.
If you get out of the car without touching the chassis, and then touch the handle of the gas hose it's quite likely that you can ignite the gas. If the gas/air mixture is right, that is.
so basically you're the igniter for an expensive by the litre flamethrower
- Franko
All you need to do is run some 4 gauge wire directly from the negative battery terminal and attach it to your big toe.. Youll never be shocked again.. (By static anyway)
- freyguy_412
- Hoodzy
ahahaha i was just looking at my possible new precidia today and i was wondering wtf those buttons were for
so now i can make up wicked lies to tell my passengers w00t
i wish my escort had one of those i always get shocked
1995 Creek Mica Blue GS
- Flashpoint2
