Custom Projector light (01-03 Civic Aftermkt) pics
Re: Custom Projector light (01-03 Civic Aftermkt) pics
I just re-read it and I think I figured it out..you cut the civic clear plastic cover to the dimensions of the mx-3 clear plastic cover...and then put the civic cover back onto the civic projector housing? Is that right? Did you have to modify the housing to stuff it in there?
My Cardomain site
My Cardomain site
- mitmaks
how about you make me some? how much would you charge
- GregoryChristian
yes, but I cut the lense a bit larger than the actual mx-3 cover and also had to cut the housing several times for proper fitment ...if I undercut them I would of been screwed, so I took my time and cut & fitted several times .... the actual light is surprisingly 3 parts ( Lense, projector housing and backing plate W/ bracketsOriginally posted by mx3man83:
** My MX-3 ** http://www.cardomain.com/ride/360367
Did you have to modify the backing plate? I think I can figure this out...I'm going to purchase a set and get to work with my little dremel tool. Is that what you used, or did you actually use some sort of saw to cut it? Close up pics would be awesome...
My Cardomain site
My Cardomain site
- monstar-mx-3
Just saw the updated pics with both in....WOW!!! When are you going to start taking orders?
- GregoryChristian
I think I am going to fiberglass the back side of the projectors for a better enclosure and make some custom bulb and turn signal ports,not really sure what to do with the 3rd as of yet... any serious ideas ? I am gonna take my time and do it right and if all goes well I wouldn't mind making some for others.. I am just glad I have gotten this far with the fitting
I really like them, would buy a set for sure if someone was making them
GuidoBiRiChiNo
Gregory, can you get some close up pics of how you mounted the lights? Also, what size bulbs do they use?
- babyblueMX3
i want them soooooooo bad...if you start producing some..hit me up
RIP 400whp ZE-T MX-3
so beautiful.....
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
GuidoBiRiChiNo
Is this the same type?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2475712371
Do them have turn signals in?
Can you post a pic with them on?
-italian lonely MX'er-
seneca
Have you guys every noticed how the boards seem to light right up at the hint of projectors for your lil beautys! Greg, you could potentially have 25 orders on the way!
A gregory christian original!
My Car Domain Page:
http://www.cardomain.com/memberpage/496099
Take a Look, leave a comment, and don't forget to vote.
- GregoryChristian
yes, that's the same type, I am currently trying to make fitment for turn signal bulbs better and will post pics....it seems the original bulbs were H1,H3 or some other small type.... Thanks guys for all the compliments!Originally posted by GuidoBiRiChiNo:
Gro Harlem
omfg....can't wait for the how-to, you PWN dood!!
DONATE TO MX-3.COM
DONATE TO MX-3.COM
