Curt, I tired to find a thread on Philips site for you that describes how Philips Vision Plus was designed and what makes it better. But they took it off the archives now. Funny.
As far as I remember, the improvements were due to higher quality components, more exact placement of filament, and more efficient filament that increased its luminance compared to others. Now, they say that Philips VP is a +50% bulb. Yes and no. +50% increase in brightenss was measured at a sertain point in the beam, not everywhere. Mind you E-code beams are pretty even in the low-beam setting. That increase was calculated only for H4 bulb and for the low beam setting. Hi-beam was +20%. And H7 bulb was only +20% in low beam. So here you go.
Sylvania Silverstar is a +30% bulb, and that is different that Osram Silverstar (E-code), with the latter being very similar to Philips VP.
But then again, +30% for what type of bulb and at what point in the beam. Being that DOT 9004/HB1 beams produce a distinct bright spot right in the middle of a single beam, I bet that is where the brightness would be calculated as being the highest. 9004/HB1 beam produces pitiful results as far as beam spread is concerned, so any increase to the side of the main spot would be beneficial.
Just to hypotheticallay compare: If I park my car with H4 headlights and regular GE/Philips/Osram/Narva, etc bulbs, they will produce better results at the horisontal extremities of the beam compared to a car with 9004/HB1 DOT headlights equipped with Sylvania Silverstars, but I bet that my car with H4 Philips Vision Plus (that I actually do own) would fair worse in the direct middle of the beam (hot-spot) than your 9004/HB1 DOT headlights with Sylvania Silverstars. Why? because DOT 9004 optics produce a very bright hot-spot as opposed to distributing the beam.
Sylvania Silverstar is a good bulb, but like anything coated to produce whiter light, it would suffer from decrease in output due to the coating. And that is what I think Aiden was trying to convey.
Comparisons are hard, because none of us owns a light meter. I think that a better comparison than a regular halogen bulb, would be a Philips Hi-vision, it is the same as Philips Premium found in ECE markets. It is also +30% bulb, so would be a better compared against Sylania Silvervision. Should be similar, but the colour of light for which you pay double.
