Flashing Hold light!
Re: Flashing Hold light!
<p>[ May 27, 2003: Message edited by: cap4004 ]</p>
1992 MX-3 kl-ze, atx-to-mtx conv.
1993 MX-3 RS atx
1993 MX-3 RS atx
How to check transmission codes when the hold light is flashing:
Under the hood, on the drivers side find the diagnostic connector. Under the cover of the connector, there should be a terminal diagram. Jump the TAT and the GND terminals. Turn the ignition to ON (no need to start the car). The flashing pattern of the hold light should have changed. The code for Vehicle Speed Sensor (common) is six short flashes followed by a 4 second pause.
Let me know if you get a different code, and I will look it up. (This info is for GS models, prob. the same for both, though.)![Cool :cool:](./images/smilies/icon_cool.gif)
1993 MX-3 RS atx
1993 MX-3 RS atx
