Yes. Fuel cutoff doesn't come until the tach reads 7800 RPM.Originally posted by ZEmadman:
how do you do that? i've got a 5spd gs and have gone over 7k(maybe 100-200 over) before but the needle kept on going, so i let off....it was as if there was no limiter.On the track we do it off the rev limiter.
am i just a wuss?
GS 0-60 times?
Re: GS 0-60 times?
Re: GS 0-60 times?
How did they come up with those times on that website? 9.2 seconds? Maybe with 4 people in the car. Or maybe that was an auto.
![Image](http://i67.photobucket.com/albums/h316/helios150/djmx3.jpg)
Re: GS 0-60 times?
Usually using a external timing device that also measures speed. Most speedos are not accurate, yours coulud read 60 but be doing 55.Originally posted by DJ:
-torp.
I don't own a Mazda.
Re: GS 0-60 times?
is there any way to re-calibrate that?
i know there's a site where you can set your wheel size and it'll tell you how long it's supposed to take you to travel one mile at a certain speed.
![Image](http://img.photobucket.com/albums/v386/zemadman/mx-3/ef032050.jpg)
Re: GS 0-60 times?
Best luck would be using a phone book and making a lot of phone calls. Shouldnt be too hard to find a tranny shop that can do it or point you in the right direction. Either way its not usually worth being worried about.
-torp.
well i notived my car has a clogged kat
so ill be removing it and adding a test pipe in the meantime while i find a free flow kat... this explaining my even slower than its supposed to be mx3
![Razz :P](./images/smilies/icon_razz.gif)
-hec
removed it and it was clogged.,...still slow lol more acceleration but slow still compared that what it used to be..maybe its because the 205-55-r16 tires and rims..maybe they are heavier..go figure..
-hec
