<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by oo7sniper:<BR><STRONG>My J-Spec B6T has numerouse parts. <P>-440cc RC Engineering Fuel Injectors<BR>-255lph Walboro RX-7 Turbo Fuel Pump<BR>-APEXi Super-AFC<BR>-NGK V-Power Resistor Plugs (closed gap to 35)<BR>-NGK Performance Resistor Plug Wires<BR>-Accel Super Stock Coil<BR>-PRM Jet Stream Cold Air Intake<BR>-APEXi Silia Inter Cooler w/ 2.25" piping<BR>-Turbo XS Type-34H Racing Bypass Valve (venting to atmosphere)<BR>-Road Race Engineering Manual Boost Controller<BR>-Mazda Speed Motor Mounts<BR>-RX-7 Air Flow Meter<BR>-Centerforce Dual Friction Clutch (Junk)<BR>-All Red Line Synthetic Fluids<BR>-Pacesetter Quick-Shift short throw shifter<BR>-SRD Bronze Oil Shifter Bushings<BR>-16" Pacer Rage Racing Rims (VERY light)<BR>-Nitto NT-450 Extreme Performance 205/40/VR16 tires<BR>-Tokico Blues<BR>-Weapon-R Circuit Pro Coil Overs<BR>-FX-Designs Combat front bumper<BR>-Eribuni Celica Hood Scoop (Fully Functional)<BR>-Auto Meter Sport-Comp Silver 5" Tach<BR>-Auto Meter Pro-Comp Silver Air/Fuel Ratio Gauge<BR>-Auto Meter Pro-Comp Silver Boost Gauge<P>And I've only just begun
There will be MANY more to come. My goal is to get my car as close to 10sec quarter mile as possible w/ the full interior still intact. It's gonna be tough!!!<P>-------------------------<P>Jeremy W. Miller<BR>93 Mazda MX-3 RS-R w/ J-Spec B6T
</STRONG><HR></BLOCKQUOTE><P><BR>IF you want 10s, you NEED big slicks and a LSD. The gearing isnt there to get deep into the 10s without BIG slicks. your current tire/spring/shock combo is far from adequate as well. Id suggest some sort of adjustable in the back at least, preferably Konis because of the rebound adjustability. Also, you have a PRM on your turbo? Thats far from ideal, and opening that up with help out quite a bit. The other thing is a good stand alone and tuning.
