new solid end links
perhapsadingo8yerbaby
Re: new solid end links
Post by perhapsadingo8yerbaby »
It does sound like a classic case of crappy endlinks then. Mine function ok but after trying to remove them to allow for install of Energy Suspension stabilizer bar bushings, appears at least some of my endlinks require cutting for removal. I've been following this post with interest because Tongue's endlinks were much more reasonable cost than what Mazda quoted me for stock replacements. I'm not completely convinced yet on their design for longevity yet though... :shrug:
babyblueMX3
Post by babyblueMX3 »
the only draw back tough I'm noticing is that they squick..only the rear passanger one..I guess i'll have to oil it or something..It's really buging..
RIP 400whp ZE-T MX-3
DJsMX-3
Post by DJsMX-3 »
Okay well i was under the car looking at thoose endlinks,never actually thought about how they worked
"all i know about cars is selftought"
But as i could see the bushings "looked" allright,but its just like a bolt incapsulated in rubber in each end,so that its abel to move around,Right??
As i see it,the rubber could be worn or maybe even have a hole around the bolt inside the rubber without it beeing visible from the outside,so they still could be whats causing the clunking...
Or will they allways be visible from the outside if theyre bad?? :confused2:
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
[quote]Originally posted by Dennis Jørgensen:
Or will they allways be visible from the outside if theyre bad?? :shrug:
DJsMX-3
Post by DJsMX-3 »
Well that was what i thought,that the endlinks could be worn inside the bushing,guess im going to change the two in the front and see if it helps "just dont know if i should get OEM-ones or theese bushingless-solid endlinks"
I guess the only other thing it can be if not my endlinks,then its the strutmounts that are clunking :)
Darcy
Post by Darcy »
Where's the best place to buy these in Canada? Anyone know?
The local Mazda shop wanted to charge me $473.08 to stick them on, but I figure this would be easy enough to do myself.
lakersfan1
Post by lakersfan1 »
Hwo are your motor mounts? When my wife's motor mounts tore, she got a NASTY clunking noise when she hit bumps.
