K serie engines turbo pipes
Dangerous Dan
Re: K serie engines turbo pipes
Post by Dangerous Dan »
well , my cpu took a shiznit again . So i'll be unavailble on aim , but here's my email addy
DangerousDanRacing@hotmail.com , i can acess at work .
Dangerous Dan Racing
Custom tc kits , clucth jobs , motor swaps ....
717-318-7597
mitmaks
Post by mitmaks »
Originally posted by 992mmx3:
Originally posted by mitmaks:
i ment mandrel tube bender, can be made at most exhaust shops around here by request for way cheaper, just gotta know what you want and size, etc
Where at Mitmaks. We live in the same state. I'd like to know because all of my piping cost is pretty consistant with Dangerous Dan's for Mandrel Bent tubing. Hell, my exhaust alone was about $400 for mandrel bent.
dont you have any exhaust shops in your city, we have a few and if I wanted id get them to mandrel bend it for cheap and i could do welding, since i can weld pretty good.
Dangerous Dan
dont you have any exhaust shops in your city, we have a few and if I wanted id get them to mandrel bend it for cheap and i could do welding, since i can weld pretty good.[/QB]
I seroisly doubt you'd be getting mandrel bends . maybe top qulity crush bends without wrinkles but not true mandrell .
a mandrel bender has outer die and a inner die(inside the pipe) to retain the id of the pipes , 99.9% of exhuast shops use only outer dies and lose id at the bend .
717-318-7597
Return to “Forced Induction”
