Car start problem.
- relisys_3200
I know this is an old post, but I've read around and discovered that there are other people having this problem to. I went to start my car this morning and discovered the same problem...I checked everything that was suggested here but still nothing. I then discovered that two of the screws that hold the distributer cap on were loose. This allowing moisture to get in. All I had to do was take a hairdryer and use it to dry up the moisture inside the cap. My car then started right up. Some problems may be deeper then this, but I'd try this also if anyone is having this problem..Hope it helps
