Your 96 is a 4 banger right? if it is u'll basically need a v6 for parts such as wiring harness, motor mounts, ect. I'd search for a BP or BPT if I were youOriginally posted by synap:
quick question, has anyone done the ZE swap in a '96 mtx? I may be doing this for around 3g's. (i hope)
KLZE how much?
Re: KLZE how much?
Re: KLZE how much?
Why would you assume that?Originally posted by Eggo:
Your 96 is a 4 banger right?Originally posted by synap:
Re: KLZE how much?
I assume this because I heard somewhere that 96 and above mx-3's in NA only came in 4 cyl models.Originally posted by lakersfan1:
I could be wrong though
- bmwm3guy
Re: KLZE how much?
you COULD be wrong...
MX-3's came in 4 and 6 cylinder models during all its years of production. Just think about it, why would Mazda get rid of the V6 when it was the cooler model?
![Werd :werd:](./images/smilies/werd.gif)
Re: KLZE how much?
I thought they got rid of the 6 in NA and made the GS package with the 4 cyl only
Re: KLZE how much?
Besides we all know the 1.8 ain't that Great of an engine thats why most of us are doing the ZE swap
Re: KLZE how much?
It's a V6. Talked to the shop today and they said getting the wiring/ecu/eng/maf should work. Just finding an eng with the maf is hard. Hope I can use the ze ecu and maf.
Re: KLZE how much?
What maf are you talking about, our car have a vaf. If you were to swap your harness to obd1 and use a klze ecu you already have the right vaf (called je-50). Our cars use the same vaf as a klze.
Re: KLZE how much?
I think the shop might be confused about the MAF/VAF the are similar. This is good news if I can get the wiring harness to obd1 and the ze ecu and keep my VAF!Originally posted by mxmaz:
Re: KLZE how much?
ok... the FUD alarm has gone off.
Production differences between USA and canada:
Canada:
RS 92-96
GS 92-96
(95/96 GSs are ODBII)
solid seatbelt mounts
USA:
RS: 92-96
GS: 92-94
motorized seatbelt mounts. There was a recall to put in the canadian solid mounts.
Canada:
RS 92-96
GS 92-96
USA:
RS: 92-96
GS: 92-94
Re: KLZE how much?
I think it'd be a hell of alot easier to try the K8 ECU with KL02 VAF first. People with OBD1 cars seem to be able to use this combination OK. That's what I'm going to be using on my car first before I worry about another $200-$300 for another ECU. Save you having to do a wiring harness swap, and if your province does inspection with emissions, they might not pass you if you put an OBD1 computer in a car that's supposed to be OBD2. Not sure. I know in my state, they don't even do an actual emissions test when you take an OBD2 car into emissions. They just hook a computer up to it to make sure there are no codes. An OBD1 car wouldn't throw the right codes.Originally posted by synap:
What maf are you talking about, our car have a vaf. If you were to swap your harness to obd1 and use a klze ecu you already have the right vaf (called je-50). Our cars use the same vaf as a klze.wee.. it's soo close!.... so i dont need a 2.5L VAF? just keep the stock K8 right? You guys rock.
Re: KLZE how much?
Are you sure 95 GS's are obd2? cause mine 95 is obd1.Originally posted by RoundTop:
Canada:
RS 92-96
GS 92-96
<small>[ November 23, 2004, 09:07 PM: Message edited by: mxmaz ]</small>
- Yoda
Re: KLZE how much?
All cars in North America are only OBDII If they were manufactured on or after Jan.1, 1996. In theory '96 model year MX-3 built and imported between 9/'95 and 12/31/'95 could still be OBDI.
Other differences in the Canuck MX-3 is all cars imported at rear wipers and Air bags were an option right to the end of '96. Also the '96 GS came with a 22mm rear anti-roll bar instead the 20mm as in previous years.
In the US there were no MX-3 in '96 and importation of the base model was discontinued in mid/late '95 due over stocks and poor sales. US models also had stiffer the stiffest of the three available OE springs rate in the front.
Canada:
RS 92-96
GS 92-96
USA:
RS: 92-96
GS: 92-94
Re: KLZE how much?
synap I think u can get a KL62 ecu to run the ZE and keep your stock wiring harness. I read on the board the KL62 is OBD2
Re: KLZE how much?
If I wasn't so tired right now, I'd go slam my head into the god damned wall right now.Originally posted by Eggo:
