put the 2.5 klde intake on now car wont idle
Mnemonic
Re: put the 2.5 klde intake on now car wont idle
Post by Mnemonic »
your right its for the EGR, i found out about 2 hours after searching and went through my box of left over parts and sure enough there was the egr with a connector that matched.
this is getting to be a head ache AAAAAAH! shoulda stayed with the 1.8 IM
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Mnemonic
Post by Mnemonic »
ok Urbanstylze (dave) swears its the connection to the Heads from the IM so im gonna go get me some gasket sealent and try it again, the gaskets are still pritty new but he is right it might not be sealing right due to the swapping of IMs and the gaskets were originally for the 2.5 then i put the 1.8 IM on it and it could of warped it a little
<small>[ July 23, 2004, 01:14 PM: Message edited by: Mnemonic ]</small>
PATDIESEL
Post by PATDIESEL »
I told you that on Wednesday when I was there, geez you should listen to me. If that works I'm goinna DDT you.
Mnemonic
Post by Mnemonic »
WOOO WHOO BACK YARD WRESTLIN! no offense pat but if you can ddt me ill give you a dollar, or ill just buy you a beer
and if i were to listen to you, where would the fun in that be? this away i get someone from moca to finally drive down to me! HOW YOU LIKE THAT DRIVE HUH HUH HUH THATS WHAT I THOUGHT :p
<small>[ July 23, 2004, 02:12 PM: Message edited by: Mnemonic ]</small>
lakersfan1
Post by lakersfan1 »
Thank god for this post. The diagram above reminded me to check my fuel lines. I can't believe I was so stupid to not be able to figure out the fuel filter out goes to the FPR.
Of course I broke the TPS pulling the lines. Luckily I've still got the TPS from the K8......somewhere.
Anyways, it'll start now, but it idles up and down, and the throttle does nothing. I'll try the spray copper sealant tomorrow and see how that does. I'll post results.
timpronk
Post by timpronk »
To check if your intake has a vacuum leak, use a length of vacuum line and put one end to your ear and the other at the spot you think its leaking. And listen for a hissing. Or you could spray wd-40 or silicone spray at the spot, and if the car revs up or down depending on what you spray, you will have found a vacuum leak.
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
lakersfan1
Would starting fluid work just the same? ......I assume?
Mnemonic
Post by Mnemonic »
2.5 im would not work at all after 1 full week of messing with it i finally gave up and put the 1.8 back on and it fired up
lakersfan1
I'm giving up on the 626 manifold with the phenolics as well. I'm going to try the 626 manifold alone as well as the MX3 manifold with the phenolics to see if one of those two combinations will work. This heat outside is kicking my *** , though. I just want to be donw with it. :mad:
