Left to right:
Fidanza flywheel - Needs a new friction surface, will be replacing w/ clutch
Short-tube headers - Will be cleaned, flanges will be re-welded to primaries(so I can polish the primaries inside)
Cam Gears - I intend to take these to my machine shop and see about lightening/balancing these with or without cams.
Unorthodox UDP - It's good to go, but I want to look into a 36-1 trigger wheel for it, for more accurate spark timing.
KL fuel rails - I'm having the bore corrected(slight run-off in both rails) and then powdercoating these black.
KJ(Milli S) injectors - To be flow-tested, new filter baskets & either new K8 or KL pintles, depending on current research... I'm kind of stubborn, and want to give my ideas on pulse-width duration a shot, since fuel rails are so incredibly easy to swap out, in comparison to other items.
Stratified PnP MegaSquirt - VAF removal, VRIS onset/duration, full replacement ECU. I need to figure out mounting for this, other than that it's ready for use!
SRD Reproduction Crossmember/Lower Tie-bar - My valvecovers and fuel rails will be Powdercoated either this color, or a slightly glossier black, I'm still undecided. The lettering will be mirror polished...
