So I installed my brushed aluminum b-pillar bar from JWMX3 - I am very pleased with the fitment/quality. I won't be able to test it out until I get the car reliable again...
Here are the installation pics - basically I decided to cut a little on the autobelt piece as well as the bar. I wasn't comfortable with shaving off any more of the belt pieces. I also opted to not break the lower clip that holds on the b-pillar plastic so I worked around and behind it.
I had to buy a bolt for each side. I have a full set of 94 belts in storage so I took that bolt to several different hardware stores before I found a suitable bolt. I wanted metric but had to go with standard. The bolt on the left is the original seatbelt bolt - 12mm 1.5 grade 10.9 metric and the bolt on the right is a 7/16-20 x 1" grade 8 bolt. The threads are identical and they went in just fine.
I also swapped rims with the DD since it needs the better rims/tires for the coming race...
I also recently went to the junkyard and got a mint gas popper/hatch popper assembly from a protege... after finding out how easy it is to install I had it done in like 10 minutes... I removed my driver's side chair and pulled up the carpet. I love how much better these look now instead of that ugly yellow and they were a little rusted too
