Alright.
I've decided that the only reasonable explanation for the compression is the cams. So I can quit worrying about that.
I changed the oil for the first time since the race day, and I've gained 5-10 PSI across the board when hot. So you CAN kill oil...
I've started some reasearch for tapping the pan to draw from it. The pickup sits maybe 1/4" off the bottom... I never knew, but then again I never thought of it.
The full line on the stick is still below the lip of the pan by about 1/4". You could put probably 2L of oil in the motor and it would idle fine, sitting still, at 1000 RPM or less, with hot oil. That means you could let it fall off the dipstick about 2L too.
If I weld my bungs on as high as possible I'd still leave at least 3L of oil in the pan, which is enough for me. I check my oil like a maniac anyway.
I was replacing temp sensors the other day and I accidentally dropped the dash sender down into my timing belt. I figured I would have to either tear it down to find it, or tear it down to reset the timing if it jumped... so I just went and cranked it over. If bounced around in there and then jammed in a bit of the covers. A little plastic O shot out and almost hit the GF, but it ran like its usual self, and the timing is still dead on.
So today I was under the hood and noticed this:
I guess it went through an idler. Oh well, it will blow when it will blow. Motor is coming out in a month or two anyway when the winter motor goes in. Then I can hunt down some oil leaks (wtf front VCG) and clean it up a bit again, replace the cork oil pan gasket, see how my magnet in there is doing, replace the pan with the tapped one, etc...
Here's one of the many reasons I love having a motor like this:
The inside of my engine is cleaner than the outside...
Black GS - Summer DD/Race car -
Fancy KLZE
