Page 16 of 19
Re: Vecia's 1994 MX-3: UPDATE - Got Me a Parts Car!
Posted: April 17th, 2012, 7:13 pm
by SuperK
no they're the same, just different head gaskets
http://www.mx-3.com/phpBB3/viewtopic.php?f=24&t=53370
A local pull a part has a full engine for 120-140 dollars, and 56 dollars for a transmission for any 4 cyl.
whichever works best for you though!
Posted: April 17th, 2012, 7:20 pm
by Vecia
Savin wrote:I believe oil/coolant passages are slightly different. limegreenmx-3 did a comparison a few years ago.
Hmmm, I'll have to go back then and read the Miata forums and find out what SOHC B6 block they are using. *Throws Fists in the air and drops to knees like the guy in Platoon* "Whyyyy!!!!!????"
at any rate, the 93 is getting a BPT no matter how you look at it. I'm keeping a B6 in my 94 but the with BPT in my 93 I definitely wont be going home...
I was pretty sure. Dang it man! You guys got me second guessing myself.
Posted: April 17th, 2012, 7:23 pm
by SuperK
now I"m confused! Ar eyou doing a head swap on your parts car or a bp?!
Isn't there a compression difference between the sohc block and dohc? the b6DE has 9.1:1 compression.
Anyways, the money you spend on a head probably would be the same for a full engine is what most of us say.
Posted: April 17th, 2012, 7:31 pm
by Vecia
SuperK wrote:now I"m confused! Ar eyou doing a head swap on your parts car or a bp?!
I see your game, man! Stop trying to confuse me!! lolol
I am DEFINITELY doing a BPT in my parts car, yes. But there is no sense in wasting the B6 block. I will bolt it up to my engine stand and rebuild it with a Miata B6 head. Then, excluding all of the stuff I said before, I will drop it in my 94. It already has everything there for the DOHC B6. The parts car will be a complete BP build from the ground up. I'll strip it bare, fix the body, replace fenders... yada yada yada, paint it, rebuild interior, suspension, brake system, exhaust... yada yada yada... You get the idea.
Posted: April 17th, 2012, 7:45 pm
by SuperK
NOOOO! Not the miata head, anything but! Didn't you go through that?
http://www.mx-3.com/phpBB3/viewtopic.ph ... ad#p600711
the only thing you want from the miata is prolly the camshafts!
NO! you cannot use a Miata B6 head gasket on a mx3 B6. the FWD motor has two extra oil passages on the exhaust side of the block, and the miata gasket only covers half of the holes, I think an older B6 out of a 323 might work though. I was the first know person to do the miata cam swap years ago in the MX. worked out great, but you really need adjustable gears to get it perfect. Huge advantage over all other B6's. I was putting down close to 230 in my B6DE with miata cams vj14 hybrid at 12psi. However the Miata BP and the Pro BP head gaskets are interchangable. all other inturnals are compatable
so wouldn't the head have the oil passages as well? mebbe not?
Posted: April 17th, 2012, 7:55 pm
by Vecia
LOLOL. Different year Miata B6 head. One of the earlier years, I can't remember which one at the moment, had the disti on the exhaust side. I actually could have kept that previous engine and just swapped the head... I'm still kicking myself for that one. Don't worry though. I will do an EXTREME amount of research before I buy anything, I promise! lol
Posted: April 17th, 2012, 8:01 pm
by SuperK
I'M JUST SAYIN'!!!
I have a problem finishing my
Posted: April 25th, 2012, 7:19 pm
by Vecia
Posted: April 25th, 2012, 7:22 pm
by SuperK
file a claim with the shipping company
Posted: April 25th, 2012, 7:31 pm
by Vecia
To be honest man, I threw all of the stuff away after I opened them and they sat on my bench for a few days before I even looked at them. Just so swamped with work and dealing with the other car. Serves me right for not taking the time like I should have.
Anyway, here's a pic of the front lip and the new bumper. As you can see, I'm quickly running out of space.
Posted: April 29th, 2012, 12:27 pm
by Vecia
Spent all weekend working like crazy...
Posted: May 19th, 2012, 9:57 am
by Vecia
Sorry I haven't been around much. I had knee surgery and then I got sick. Slowly coming back around.
Posted: May 19th, 2012, 11:35 pm
by MrMazda92
Just keep it coming! I like what I'm seeing. Parts from 2 cars coming together, both get to "live on" in a sense!
Re: Vecia's 1994 MX-3: UPDATE - 6/20/12
Posted: June 20th, 2012, 10:07 pm
by Vecia
Okay, so I'm getting back in the groove of things. I'm back to work and the knee is healing awesome.
First misc. project to start was the "hatch key lock delete"
It actually turned out awesome. I screwed up the bondo a few times but after a quick scrape and recasting some new stuff, I finally got it.
Sorry this is such a small update but I'll be adding more soon. Thanks!
Posted: June 20th, 2012, 11:00 pm
by AaronTietje
Nice shave job on the hatch.
